What did you do to your non-G body project today? [2021]
Does it count when you pay someone to do it?
A year ago we drain tiled our house due to some water issues and installed window wells for egress windows while the dirt was all dug. Was going to hire a friend to cut holes but they got busy and baked out and I didn't know how they did it so we punted the project.
Wife saw a post on FB marketplace about egress window installation, we contacted him, he came out and quoted something actually reasonable and came out yesterday and today and cut the holes and framed the windows in.
$600 each labor so not cheap but way less that a lot of other places. Good results and no complaints.
I would probably dig my own grave I'm so cheap but this is one case where paying someone might have been right.
One thing I don't see is the addition of a steel plate threshold inserted to help support the bricks over the new opening? Usually up here they remove the mortar for a few inches away from either side under the new bottom course of brickwork and insert a 4 or however many inch deep piece of plate steel that's at least 1/8 to 3/16 thick and about 2-3 inches wider on each side of the opening. Slide it right into place where the mortar used to be
Helps support and prevent cracking from traveling up the mortar, between the stonework. (Because nobody likes to repoint)
Or could just be obscured?
Also past experience... how's the drainage? We had some water intrusion issues during snow melt season mostly, was a PITA until we dealt with it the right way
Replaced the steering gearbox seals on the tractor which involves removing the front axle.
Whole project actually started because of insufficient drainage. House is on clay and we had some water leaking through the moarter seam hairline cracks when we got big rains.
That led to us trenching around the house to the footer where we installed drain tile and pea rock and tar/sealed the walls.
Since the trench was dug we put window wells in for egress. So the answer is yeah, drainage is great.
So we don't have a steel piece but the installer did frame the window in with 2x12's and the top of the frame is flush to the brick facade, so I guess we'll see if we get any cracks. It's supported but I'm not sure if it's enough. If we do get any cracks I'll have to go with your method, it does sound the most correct.
Apart from the question of the steel upper sill plate, something I did suggest as part of another thread that got posted last year sometime as being structurally desirable , did your installer happen to inform you as to whether he had had to pull a permit for the work and if someone would be along from the local building department of City Hall to inspect it? Me being suspicious here but the nasty idea of your price being so reasonable being possibly due to it being unpermitted did comment itself to me for some consideration. Building Inspectors likely go the same school as tax collectors as they both seem to share the same degree of obstinacy and determination when it comes to getting their way.
This first picture is just a shot of the relocated lower pair of fairing mounting studs as they appear prior to final sanding and paint
This second picture is a close up of the left side lower stud. Multiple layers of resin later you can see how smooth and totally embedded the stud has become. For those who follow my threads from time to time, I did finally choose to use the steel expanded micro mesh. The square of material I used is not all that large as it doesn't change shape all that easily and kept wanting to return to being flat. Once I set the first heavy layer of resin in place it that locked it down and successive layers have completely buried it. The biggest pain was needing to have lay multiple layers of resin, each having to be sanded down once cured, to get the shape of the surrounding shoulders to take on the general shape and curves of the surrounding fibreglass while keeping the general profile as low as possible, The right side stud is a mirror image of the left, so no picture required.
And this last shot is the same left side stud, now with a wrap of painter's tape to keep the freshly chased and clean threads of the stud from getting contaminated by the primer and top coat. At this point the last round of sanding was done using either 120 or 180 production paper and the scratches are still visible. The next series of sanding will be with wet/dry and done wet to keep the dust down. The last grit will be a 320 and after that comes the primer.
I am not heavily concerned about the painting process as this is the underside or back side of the fairing and the only way anyone will get to see it is if they are either sitting on the bike or have just come through it due to a case of terminal stupidity; a situation I would not want to have happen just on general principals.
When I did the reconstruction of this component, it received several more layers of glass and resin than it had been born with. These units are typically made by using a form and applying a heavy layer of gel coat to the inside surface. Then a chopper gun is used to spray finely chopped fibreglass strands into the mold with the glass getting its resin bonding coat at about the same time it leaves the gun nozzle. That way the gun hoses and nozzles stay free and unclogged with resin. Still a messy job.. The final shape is only about an 1/8th of an inch thick or less, meaning it cracks and breaks easily under stress or hard impact. In its new and improved? version it is about 50% thicker with both fibre glass matt and cloth being used in alternate layers for strength. If I can ever discover where I stashed the cans of new gel coat the outer surface will get sanded smooth and several fresh layers of new gel will get laid, sanded and buffed out. I could skip the whole gel coat drill if I elected to mural the outer surface but they are expensive to get done and hard to protect and maintain, plus it would no longer match the bags and tourpack, all of which are white.
This will likely be my last foray into the world of fibreglass, My lungs are as old as I am and the older they get, the more sensitive they seem to be getting to dust and mold and fumes and vapors, all of which are an integral aspect of working with glass. The local weather doesn't seem to be helping either with the sun being out but the air cold and damp. NOT good for clean breathing.
I got the joy of finding out that my newly bought Grand Cherokee has a burnt #1 piston.
When I bought it, it had a check engine light on that turned out to be a Cyl. 1 misfire. I cleared the code and it did not return, but it gave a different code for the MDS system. Not uncommon for an MDS solenoid to fail and cause wonkiness, so I scheduled it into the local Chrysler dealer and they determined something in the bottom end had gone south. I then talked to the dealer that I bought it from and they agreed to go half on a replacement motor. Now it sits on my car trailer waiting on the appointment to get it replaced.
I hate to say it, but I am beginning to see the appeal of just buying new vehicles. Even more since while I was at the Chrysler dealer, I test drove a diesel Gladiator. I need one of those things.
Bought new door panels, metal door handle cups (stock are plastic), a new gas tank, new p/s pump and lines, and window channel seals.
The other door panels shattered when I pulled on them to close the doors over the winter, the "new" tank the tweakers put in before i got the truck is seeping somewhere on the bottom, the ps cooler metal line loop thing is crusty and moist and the hoses are dry rotten and split, and lastly the window seals are gone. It's so god damn loud in that truck above 45mph its like driving through the air blower part of a carwash sound wise. Plus the windows rattling is driving me insane.
Got some parts ready to be powdered teal and then ordered a bunch more stuff. Pulled the trigger monday on the wheels and then yesterday all the stereo bits, I'm going to pull the bigger Monte radio and put it in the Blazer. Then ordered a 13.3 double din to put into the Monte that is able to power swivel from landscape to portrait. For reference I went graphite grey for the whole wheel with teal hardware
$$$$$ to get that done around here. Not even sure if there is a local vendor that does powder. The provincial people's social commune of tree huggers and weasel squeezers have their enviro hooks solidly into the love the environment mode and do nothing but holler, yodel, and whine (sounds like a law firm (LOL) ) about anything that is positive for economic growth and development but could impact the environment negatively. Think they took classes from the Greens in Europe.
Reactions: scoti
