What did you do to your non-G body project today? [2022]
That's one of the cleanest looking rear frames on a tractor I can remember that wasn't new on a sales floor. Must get weekly washes
This thing was really clean when I bought it a couple years ago. It came from the Eastern side of the state, a Kubota dealer near Reading PA had it. I pressure wash it twice a year and give it a heavy coat of Fluid Film before winter but it does do snow plow duty. I try to blow the grass off of it after each mow with the leaf blower.
That mount looks like that bracket for the Hpipe, it stretched?
When I did my TSP Stainless Long Tubes I managed to relocate the front O2 Connectors far enough back along the Bell Housing to reach both Sensors on each side. It's tight but the wires are not taught, they are good. Rear Connectors I made plugs for similar to what you did, and turned them off in the tune.
The Steering Shaft I ran into the same, upon install I turned it down on the lathe to help but had slight rubbing on a right turn. When I had the Headers out of the car the last time for the Speed Bleeder install, I clearanced them with my air hammer. Nice .250" gap now, no issues. 🙂
Pic here was the before..
Mine was just as close. Could slide a couple pieces of paper between them at rest. Where are your O2 bungs? I wonder if yours aren't farther forward? I can't see delooming getting me what I need here.
Take a second look at the pic of that h pipe mount: it's in 3 pieces. Or rather it was.
Hmmm... plow-check, yellow-check, CDL holder-check. This proves you are state operator material. KDKA's 10 o'clock news had a story about your county's district needing operators.
homer simpson eating GIF
joesregalproject , just buy a strobe light and some flashers and your good to go!
Made a lot of progress tonight the last 2 body bolts are in the running boards are on. I put a horn in and put the front bumper back on
Even shut the hood and took a picture of that because I like it.
That's probably why I went black on black with all the aftermarket parts.
Obviously you can see it's location has changed by a few feet I was hoping to idle it outside but...... It's mine so it's a gift that keeps on giving! I've got a massive fuel leak. Possibly more than one because I found one but it's not bad enough to make this lake under the truck
So I guess tomorrow I'll clean up the shop and back it back in the hole to take it back apart and go back over the fuel system again. At this point I just expect problems. Hopefully it's an easy fix
Maybe so, but if it develops a rust bubble he'll probably part it out.
Made a lot of progress tonight the last 2 body bolts are in the running boards are on. I put a horn in and put the front bumper back on View attachment 205438View attachment 205439View attachment 205440
Even shut the hood and took a picture of that because I like it.View attachment 205442
Obviously you can see it's location has changed by a few feet I was hoping to idle it outside but...... It's mine so it's a gift that keeps on giving! I've got a massive fuel leak. Possibly more than one because I found one but it's not bad enough to make this lake under the truckView attachment 205443View attachment 205444
So. . . fix the leaks and roll coal?
Still trying to figure out how that mount got messed up.
My 02 Bungs are in the collectors. I got the wires to reach with minimal modifications.
