Like your description of the oil mess! Always tell trainees” if you ever had to clean up after a qt of oil ,think 5,10,or even 100 gallons of it, just this is Teflon liquid “. Some get it ,most don’t. And I always tell them “You will spill it, just a matter of when.”So the original plan was to finish the oil charge on the compressor's crankcase and to that end I had paid a visit to the service shop and picked up a gallon of 30W Premium mineral oil. The old oil had been left to drain out overnight as it was about as stiff as molasses and slower than an 16 year old trying to avoid school. About to add some layers and head out to the back when I get the sounds of diesel coming from the front street. 1/2 hr later I am in the front driveway with a scoop and moving out what the plow dropped off; a wet mushy heavy pile of white crap, one half scoop at a time because this stuff is cement snow, aka heart attack snow and mostly water held together by obstinancy.
Get that done and out into the shop. Dump the oil bucket that had been left to catch the drain down; about full and more in it that I had would have been the case. Rethread the cap onto the drain pipe and set the petcock back to closed.
Normally the refill would have been an hour of funnel and slow pour work but this time I decided to score a small siphon pump from the local big box car parts store and use that. Took about 8 repetitions and maybe 1/2 hour but got the oil in and minimized the mess and slop in the process. Fired up the compressor and let it build up some pressure.
Went ahead and pulled the air filters and blew them clean, then re-installed them. Now for the why of this.
When I put my Non-G-body --GBody away for the winter, the relief valve on the Canton Pre-oiler had started to hiccup and spit oil out of the reservoir. During the winter I had Canton send me some replacement valves so's I could do a valve swap. Thing here is, to do the swap you have to drain the air pressure side of the reservoir to take the pressure off the oil side. Once you do the swap, the tank has to be repressurized as fast as possible to equalize the two chambers. If not, well I have what is left of the original tank sitting over in the corner; they do blow up quite suddenly and thoroughly; drove the one end cap right off its threads and down into the inner wheel well cavity. Good thing it happened in the front driveway or I would have lost the whole oil pan into the bargain. Nothing like having to deal with 5 quarts of oil that just got vomited all over an asphalt drive to ruin a week.
So got that done, Lifted the main door to check on the snow/ice pack and removed some of the immediate crud away from the door sill. Closed the door and discovered that the upper weather seall was still not sitting tight against the upper door frame so now i have to pay yet another visit to Home Deppott to see if they have a long flap door seal that I can PK screw to the upper leading edge of the door. Bother. Fortunately the internal and ambient temps right now are just about equal so the furnace isn't likely to fire off.
