what would cause the same symptoms as a clogged fuel filter
Texas82GP
Just-a-worm
Apr 3, 2015
7,989
18,702
Spring, Texas
How much do you know about the coil and control module? Did you confirm the pump is providing sufficient fuel pressure?
I wouldn't do anything else until you get that TPS calibrated.
pontiacgp
blank
Mar 31, 2006
29,270
20,397
Kitchener, Ontario
From what I have read the TPS does not affect the secondaries or when at WOT
Texas82GP
Just-a-worm
Apr 3, 2015
7,989
18,702
Spring, Texas
But would it have an impact on the Mixture Control Solenoid? I wonder if it is going to full rich at WOT? It's admittedly been 20 years since I worked on a CCC carb.
pontiacgp
blank
Mar 31, 2006
29,270
20,397
Kitchener, Ontario
If that were my carburetor I would pick up a good book on the E4M, read it and then rebuild the carburetor.
Texas82GP
Just-a-worm
Apr 3, 2015
7,989
18,702
Spring, Texas
The best thing would be to follow the factory diagnostic proceedure, but checking the basics (fuel pressure, etc.) won't hurt.
pontiacgp
blank
Mar 31, 2006
29,270
20,397
Kitchener, Ontario
at WOT the loop is open and the secondaries are no different than on a non E carb
84 delta 88
Feb 15, 2015
50
7
8
I replaced the entire ignition system except for the module about a week ago the pump is brand new put it on about 4 hours ago so its providing sufficient flow
Clone TIE Pilot
3,869
2,621
Galaxy far far away
The needle valve may be sticking.
If you broke the TPS, you also may have bent the TPS plunger rod in the airhorn. Did you use a putty knife to hold the TPS in place when reinstalling the airhorn?
84 delta 88
Feb 15, 2015
50
7
8
Same thing happened to my 307. I practically worked around the problem until I replaced the carb. Filter, Fuel pump and Timing chain. Pulled one out of a Lesabre and it ran just fine. Changed out the secondary metering rods and hangers for the one that were on the original 442 carb and added some timing into it,Timing chain should be replaced too if it's passed 100k. Trying to "rebuild" a ccc Q Jet is a task. If you can get your hands on a localy used one then do it.
Sounds crazy but if your running a 200r4 check and see if the tcc is stuck, just disconnect the plug underneath and drive it. see if that changes anything.
I'm running a 200 metric 3 speed with a lockup converter but I do not believe its functioning correctly could it cause these symptoms if it were constantly locking and unlocking under wot
84 delta 88
Feb 15, 2015
50
7
8
ok i attempted to calibrate my tps I adjusted it to spec .37 to .43 volts at idle the book also says it should read at leat 4 volts at wot however mine is only reading 3.3 does this mean my new tps is also bad
