i just got my swap done on my cutlass and it is doing something i cant figure out. the car will be running absolutly perfect and then in a flash it will be running as if the timing was terribly off. i can give it gas and it will take off like a bat out of hell and then cut out then go then cut out. i have torn the carb apart and checked it, i replaced the cap and rotor, i have checked my firing order 3 times, i have swapped the fuel pump and checked pressure. alternator and battery is good, wires are good, connections all look to be good. i am mind boggeled. the engine is a 355 chevy with a bunch of performance stuff installed, vacum advance hei distributor, th350 transmission..... could the distributor cause it to do something this wierd? i drove it around for a hour 2 nights ago and it ran perfect the whole time, the next morning i drove it to work and it acted wierd all the way to work, at lunch it drove perfect again and then after work bad. i am stumped!
