1983 Oldsmobile Cutlass Supreme Sedan LS Turbo Build
GroceryGetter83
LS Mafia
676
2,406
Tampa, Florida
More goodies:
Trunnion upgrades:
Stock un-captured needle bearings:
Can't wait to see a turbo behind this grill/headlight:
:love:
Reactions: 4 users
uneek1976
653
129
Sugar Grove IL/ Chicago
You have a very nice setup going there sir! My goal is to have a turbo and a/c in the factory location and have the oil drain in the front cover as well. Just got the a/c compressor installed the rest is going to inquire some :unsure: but shouldn't be too bad. I'll be following your build man...
GroceryGetter83
LS Mafia
676
2,406
Tampa, Florida
You have a very going there sir! My goal is to have a turbo and a/c in the factory location and have the oil drain in the front cover as well. Just got the a/c compressor installed the rest is going to inquire some :unsure: but shouldn't be too bad. I'll be following your build man...
Thanks! I need AC too, living in FL :cool:
Injectedcutty
G body LS mafia
Nov 24, 2014
6,057
22,811
Louisville, KY
Them trunnion upgrades are a must!!! I used the Straub kit on mine, essentially the same thing. However, I used the BTR .660 springs and pushrods since BTR is local to me and they have nice stuff!!!
Reactions: 5 users
GroceryGetter83
LS Mafia
676
2,406
Tampa, Florida
Them trunnion upgrades are a must!!! I used the Straub kit on mine, essentially the same thing. However, I used the BTR .660 springs and pushrods since BTR is local to me and they have nice stuff!!! View attachment 102453
I haven't pulled the trigger on springs yet. Either PAC 1218 or the BTR. All depends on which camshaft I go with...
GroceryGetter83
LS Mafia
676
2,406
Tampa, Florida
Bought myself some HF stuff:
I plan on modifying the welder to DC output to get some better welds out of it (hotter welds, less slag spraying). Shouldn't cost more than $50 to add to the needed components.
Seeming how my townhouse rental only has 110V, 20 amp power in the garage, my options were kind of limited and will be fun to practice learning a new skill.
Reactions: 4 users
GroceryGetter83
LS Mafia
676
2,406
Tampa, Florida
BTR Stage 1 turbo camshaft:
Also picked up some LS1/LS6 head gaskets
Reactions: 5 users
GroceryGetter83
LS Mafia
676
2,406
Tampa, Florida
Picked up another set of truck injectors, decapped them, will send 16 off for flow testing/cleaning:
GroceryGetter83
LS Mafia
676
2,406
Tampa, Florida
Good things and bad things happened last night:
Lubed up the (cam) shaft for insertion:
Got the timing marks lined up (after everything was torqued, spun the motor over once to check marks):
Buttoned up the front:
BUT I broke the pan with the incorrect bolt sequence...should have done the two pan bolts first: :cry:
It's a truck pan, so its cheap enough to find another.
Also, the oil feed return will be tricky as someone mentioned, about 1" of clearance, will need to get some different fittings:
  • Sad
