I’ll point out something that fubar’d me for a couple of minutes. The Holley wire designated for the fuel pump is 12v+ switched, but all of the outputs are ground (12v-) switched. The reason being, I believe, is that the Holley designated fuel pump wire can carry 10-20 amps meaning it can actually run a pump, not just a relay.No wiggle on shift, or launch. Figured it was severely hurt and I was loosing power through the trans.
For whatever reason, with the relay I tried using the second pump would stay on the entire time the key was turned to ignition. Will re-visit today.
If you wired your second pump in the same manner it will run all the time. Duke sent me one of your tunes, I’ll take a look and see how it’s set.
