1983 Oldsmobile Cutlass Supreme Sedan LS Turbo Build
GroceryGetter83
LS Mafia
676
2,406
Tampa, Florida
The turbo cover upgrade wasn’t a needed modification, but a sort of an impromptu change. I figured it couldn’t hurt anything, besides my wallet slightly.
Collectively we are all learning from each other, which is a major part of posting on this forum.
Thankfully I have lots of passes on the set up and street miles (2k+) so I should be able to sense any difference quickly.
I’ll be adding a back pressure sensor shortly for data collection and understanding where I am with the turbo limit.
My new goal for the car is to get into the 8s. After I get the suspension and cage installed, the turbo will likely be my limiting factor.
Build, race, break(upgrade), repeat ❤️
GroceryGetter83
LS Mafia
676
2,406
Tampa, Florida
5,711
12,223
FYI - I have pass envy ;(
I hope you can see an 8. Damn that would be great.
Northernregal
Sloppy McRodbender
Oct 24, 2017
3,359
12,828
Saskatchewan Yoda tames the hellkitty with the spicy air.
GroceryGetter83
LS Mafia
676
2,406
Tampa, Florida
8.999 @ 3940 lbs (adding 100 lbs for cage) would take over 1000 whp. Not doing to happen with this turbo!
An 88mm tho… 🧐
5,711
12,223
Didn't you buy the tool to lock the flex plate via the starter bolt holes - to use for tightening the balancer bolt?
How did it work out?
GroceryGetter83
LS Mafia
676
2,406
Tampa, Florida
I did purchase, but did not use. When I found the PS pulley was misaligned with the straight edge, I fixed that. I returned the flex plate holder.
