FE3X CLONE said:bfurches said:dogshit said:I would be stuffing a th200 under the car with its 2.74 first and let it eat...
If a TH-2004R can handle the boost from a Grand National's V6 it surely can handle any power out of a 307, boosted or not.
I've had a built TH-2004R in the past that was behind my 455 for years. Daily drove that car and never had a problem. Ended up destroying the converter but was lucky that it just turned the fluid pitch black but that trans just kept going. Flushed it out and installed the trans behind my brother's 403 and it's still been going strong.
Sorry for the confusion, I was not bashing the 2004r....the th200 transmission is an anemic 3 spd produced in the 70's I was refering to. It has a nice low gear from a performance standpoint, and the transmission itself is fairly compact and light, but they don't hold up very well without some really expensive parts.
__________________________________________________________________
In regards to the other post, there are several good points made about having the od in a street application. I will have to look into what the hard parts cost, and maybe I will reconsider, but im still up in the air.
Cost is a big factor here...I have a lot of the th350 stuff already, and parts like convertors are relativley cheaper when compared to the 2004r stuff....but regardless I will take the sugestions into consideration and at the very least look at the cost of the hard parts i would need.
th350 weighs in at 10lbs less then the 2004r, but the 200 has a better first gear. I believe the 2004r robs a little less power than the th350, but the th350 is a little more stout...
Thanks guys.
