200-4r advice
somaphox
Jan 16, 2015
67
13
i know i asked awhile ago and no one really had any answers so not expecting a miracle since thisnt isnt so much of a transmission board as it is mod,engine rebuild and swap so if anyone has any advice on a site i should look into id be very appriciative.anyway if anyone knows when adjusting the tv system on the 200-4r and your looking through the tv sight hole is it supposed to be between the two notches of the tv valve completely untouched or when loaded as it is when the throttle valve cable is set into place and adjusted.i know it wants to be dead center on the tv valve i just dont know if its supposed to be under slight load(i.e. when the pressure is put on by the throttle valve being hooked up and adjusted at the carb) or if its supposed to be dead center fully extended.any help would be awesome
6,833
6,743
First, you should have a cable that has the black teardrop end like the picture. Second, it's a throttle valve cable. It relies on the position of the throttle to pick whatever gear. The cable should be fully extended when the carb is at full open, and fully retracted when at idle. That gives a good starting point, and you can make minute adjustments tighter or looser to fine tune how you want it to shift. The cable has to be on the low part of the throttle arm, and has to me nearly parallel with the intake for proper geometry. Here's also a small superchevy article on adjusting it: http://www.superchevy.com/how-to/65138-adjusting-tv-cable/
somaphox
Jan 16, 2015
67
13
nooo i comletely understand that and have the correct geomtry and set up but i got a valve body off ebay and everything is fine ecept the location of the tv valve in the body itself.basically i found the info i needed off bowtie overdrives website of the short stroke vs long stroke conditions and have to get a little longer spring than one that i have and alittle shorter than another one i have lol.sorry for the mix up guys
somaphox
Jan 16, 2015
67
13
also agree with pontiacgp,no disrespect but it is bad practice and will burn up these trannys fast is you try to adjust the shift points via the cable.a notch tighter or shorter is generally ok but much more is bad
6,833
6,743
That's what I mean. You can adjust it very minutely one way or the other, but I mean minute.
