BUILD THREAD 81 Buick/Olds Turbo Wagon 02/15/2024 More Parts!
liquidh8
Re: 81 Century/GN Wagon Update 6/17/14 Chassis assembly!!!
Tuggy24g said:
Finally your getting some progress on the wagon! Maybe in 2016 we can finally cruise together!
Yeah man, I hope to have it on the road at the end of the year, or in the beginning of 2015. I have some military obligations that are throwing a wrench in my build, so we'll see.
liquidh8
Chassis is rolling.[emoji1]
Brakes
12,178
9,798
Looks great , Jim.
I'm impressed with your progress. :eek:
1evilregal
3,056
4,357
Greensboro, NC
excellent progress! makes me feel pretty lazy that its take 3 weeks or so just to yank the L/S axle out of the back of my truck and start cleaning it up..... :?
20,413
I just remembered a problem I had with my car. If you have used 1/2" taller lower ball you may have an issue with the lowers. The outer edge of the lower control sits in the opening in the rotor above the braking surface. When you put in a taller lower ball joint that lowers the control arm 1/2" and that causes the outer edge of the lower control arm to ride on the braking surface of the rotor. I ruined a set of rotors on mine before I could figure out what the funny feel was in the steering. You won't see the problem with the car up in the air like you have but if you the wheel at ride height you'll see if you have a problem.
Tuggy24g
658
16
Newtown PA
Its all good man. I'm just busting your chops .it's always better to take your time and do things right the first time then having to go back and do it again because you half assed it.
liquidh8
Longroof79 said:
Looks great , Jim.
Thanks Jack! I hope to get some brake lines run today, not gonna get a whole lot done over the weekend. :(
I understand your pain, that's for sure. seems to be taking me forever just to bolt some clean parts together, haha.
I have used the 1/2" taller. After some reading about alignment problems, ball joint range of motion and the like, I put the front end together without springs. Control arms, rotors and wheels. The balljoints never bind, and nothing hits. I have the 13" rotors, no backing plates. And with the offset cross shafts, I won't have a huge shim pack to get the caster and camber in. I "should" be good. We'll see, :D
Oh I know, no worries. :D I am taking my time, just for that reason!
liquidh8
Got the fuel and brake lines all bent. I used the nice stainless clamps amd machine screws. I drilled and tapped the holes. I have to remove the feed and return to put the tube nuts and sleeves on, that is why they are long still.
I just got the engine and trans in.
I still have to run the nitrous line too. Since the engine is in now, I know where it has to go.
The control arms look orange in some of these pics,[emoji20] I assure you they are red like the valve covers.
12,178
9,798
:notworthy: :notworthy: :notworthy: :notworthy: :notworthy: :notworthy: :wink: :-D :friday:
I second that...it looks great! Maybe we'll make it to Carlisle next year. :wink:
