BUILD THREAD 86 GP 2+2~Blown 6.0
I'm of no help with your HP Tuner tables converting grams of air to PSI or KPA, but I will add that Happel's timing with the LSA should be close for you with the exception of similar peak torque values. Your 6.0 is should be making peak torque sooner than a 4.8, but I wouldn't put much faith in that without some real dyno time.
Personally, with my lack of knowledge described above, I'm 110% that you can add 5 degrees everywhere if you have at least 70% ethanol in it. And I'd spring for a dyno session somewhere to get that beetch dialed in. I'm sure you're onto your bog issue going away.
I understand the 'budgetness' of what you're doing, but man, would a Holley, MS or Haltech make this thing GOOOOOOOO much easier IMHO.
Rethinking some of your past runs and ET's, I'm think you're about to be holding on for dear life. Another 5 degrees on top should be adding 60-100hp. And that's 5 degrees for a starting point!
You know you want those extra 100 ponies on the top end....
I checked and I'm running at 1.7g at 10 psi. It looks like 1.2g is atmospheric 1 bar. I'm way of the table. The ecm has the 2 bar enhancement but I think that only applies to the VE table. I'm assuming it defaults to the highest value and just keeps going? The LSA pcm is factory 2bar so it has air density values up to 1.8g+ where mine stop at 1.2g.
I've always been hesitant to put timing in because I always told myself I can't use the power I have, but really it might be a lack of power off the hit that makes it slow and bog.
There is a local chassis Dyno. I've been putting off going to him but I'm getting to the point where I think spending some time on it would be well spent. The other option is a more street tuning guy but he has a ton of experience with LSA stuff so I can't go wrong there either.
It traps 119-122 mph in the quarter as it sits with 13 degrees. 50-100+ HP is going to make it move out. And I still have 2 more psi of boost sitting in a pulley I have on the bench.
I've got a plan forward at least.
Dyno. If the tuner is good itll shock you what he manages to squeeze out of it.
Reactions: 64nailhead
Is that a local dino or tuner? I would be interested in a local tuner if they are good. I understand the fuel and timing maps just fine, i just don't like that stuff and do not enjoy it. I get enough of different software and computer systems at work. I don't want to do that in my free time. Sounds like your combination is only going to get better.
He is in Rochester MN. Steven Kiehne. He does a lot of Holley stuff for some of the hotter street/drag cars in the area.
I gotta bug him and see if he still wants to do HPtuners stuff.
I downloaded the termX software to compare timing tables. (Yeah termX is like a magnitude of complexity more simple than HPT)
Happel runs a solid 5 degrees more timing pretty much everywhere in boost than I am on flex fuel. LSA stock is 10°+ everywhere on gas. I'm on board that I can add 5 degrees as a baseline and have (knock on wood) near-zero rod bending ill effects.
Seth Meyers Lol GIF by Late Night with Seth Meyers
We're waiting. It is a 5 minute process. Results please.
star wars darth GIF
You can datalog knock ya know. Chop chop!
