You know we are all kidding with you... It looks BADASS Scott!
So I've been kinda quiet about it as I've been troubleshooting for the past several months, but having weird brake system issues. When I press the pedal everything works as intended, but the pedal doesn't really return to the "home" position. I've gotten used to putting my toes behind pedal and pulling it back. Not sure if this is an issue with my electric vacuum pump which is designed for power brakes, or my aftermarket booster and/or master cylinder setup.
I figured the easiest to start with was swapping manifold vacuum source back to the intake as designed from factory. I grabbed a couple fittings at speed shop today, then luckily had enough hose laying around to make up a piece. It blends in pretty good with fancy loom on it, hopefully it helps as I really don't wanna pull the booster! I'll try to test tomorrow and report back, and if anyone has any suggestions let me know!
The engine doesn't make enough vacuum and you had to use an electric vacuum pump, or you just wanted to?
Reactions: Tony1968
Do you feel like you have power assist? You can test the booster to see if it holds vacuum. If it's leaking vacuum, normally you'd have a hard pedal.
