when boxing the frame you need to tack weld in bars across the C channels so the channels won't bow or warp when welding the plates to the C channel
I'm not welding for long periods of time. About 3-4" beads at a time. Then alternate to the opposite end.
Updates: I got a can of interior paint from Mike's Montes to paint my GP dash. Color looks awesome but for some reason I kept having dry spots show up on the passenger side. After numerous attempts of scuffing it down with scotchbrite and cleaning it I ran out of paint so I will have to order more. $18 a can sucks!
I got the frame notch done and by done I mean everything is cut, fitted, and tacked. My buddy has a good MIG I will be having him finish the welds since my little 110 sheet metal MIG isn't too fond of sh*t that thick. I will be adding bracing to the rear control arm mounts and adding a crossmember to the rear right behind the upper shock mounts.
I started a little shock mount brace with some small tube I had laying around. Basically gonna be the same thing that UMI sells but mines welded in. I ran out of cutting discs so progress stalled.
And my new wheels FINALLY came in! I have been checking tracking all week counting down to their arrival. They were supposed to be here next tuesday but Fedex dropped them off today. Fitment is good but I will need the frame notch. The wheel alone is about 1/4" away from the frame rail. I thought with 5" of backspacing they would be closer so im happy. Not sure if I wanna go with a 10.5 or 11.5 ET Street. I have been reading that an 11.5 is recommended on nothing thinner than a 9.5" wide wheel. Mine is 9" so im not sure how much it matters...
