For the first time in my life I am not being a TOTAL tightwad-
The motor mounts on the carb turbo and SFI engines aren't broken, but even if I replaced them on the carb turbo when I built the car they are 13 years old (and I was even cheaper then so I highly assume they are just stock OEM 1980 mounts), and I know I didn't buy a set when I put the SFI engine in the Wagon, so I am likely dealing with 40 year old mounts. OK, I'll replace them.
I am OK spending more than $7 for some rubber OE style replacements so I thought I would look for aftermarket ones.
Look at aftermarket ones. COUGH. Nope. Going with $7 ones...
Doesn't HRParts sell just the DS separate? It would be the wise compromise. I got one of the first ones ever made for my old TR... it was a massive improvement over the torque strap/chain solution. Your stock $7 mounts lasted 13 years because the engine was gutless, the beans that should be put out with the new combo is going to eat them alive.
Also, you could just build one using the donor old mount for parts and dimensions.
