Kinda struggle bussed tonight
Wanted to button up under the car and finish the exhaust, trans hardware, fuel system and maybe look at getting the last bit of wiring done.
Swapped the welder to stainless wire to burn the O2 sensor bung in the downpipe and stitch the ball coupler off the wagon test pipe to the test pipe on the cutlass. Ended up with birdcrap welds likely due to old oil and exhaust impregnated metal but it's done.
Tried getting the trans bellhousing bolts done but couldn't get the top right bolt in because the dipstick alignment was crap. Turns out the main engine harness runs behind the dipstick not Infront. So pulled that out after fighting with it for too long and then the trans puked what felt like a gallon of ATF on the floor soaking all the tools that were used to torque the bellhousing hardware.
Decided the dipstick tube needed to be black anyway and not farm implement red like i thought it should be when I was 15 so that's drying.
Did finish the fuel system plumbing and just need to flush the system and tighten all the fittings so some success.
Exxon-valdez location: my garage
Bird quap welds
Flex fuel incoming
