Best LS Conversion Motor Mount for G Body Swap (let me know which is your pick)
X
xcookpac
Mar 15, 2012
72
8
I am considering an LS swap into my 1985 El Camino (currently with the warmed over 305). I am trying to find the best LS conversion motor mount for a gbody swap. I would love to hear opinions as to which is best. My thinking is that the criteria for best LS conversion motor mount should be:
1. Quality of fit onto LS motor;
2. Quality of materials (it appears to me that steel mount would be significantly stronger);
3. Whether LS Conversion motor mount gets the LS motor into the same position as the original 305;
4. Adjustability of mount (I do not know whether this is needed if the mount is a dedicated gbody conversion mount); and
5. Cost of the LS conversion motor mount.
Let me know whether there are other criteria that should be considered.
Anubis
Anubis
1,857
There are many options but you are asking the wrong question. The problem with a G body swap isn't just the motor mounts. Headers, exhaust, oil pan and transmission cross member fitment is also a big issue. Hooker / Holley makes a complete system that is designed to work together as a system. It fits perfect and unlike other systems does not create issues like a low hanging oil pan and huge engine inclination angle.
Dirty ***** sells a sliding type mount but not sure what it does to the engine height.
Reactions: gbodytoys
G
GPNX
Jun 6, 2016
98
there's a lot more to an ls swap than motor mounts. even after you get everything to fit right you still have wiring harness, fuel lines, throttle, air induction, cooling, computer tune. i would do a lot of research before you started. this site has many good things to get you started.
Reactions: Injectedcutty
X
xcookpac
Mar 15, 2012
72
8
Thanks!!!
X
xcookpac
Mar 15, 2012
72
8
Thanks!!!!!
Northernregal
Northernregal
1,129
Red Deer AB
If you want to place the motor in the stock location then the hooker mounts are a win, they do require their expensive pan but it will fit and there is plenty of knowledge base behind the system. If you want options later for trans swaps or fancy exhausts, they supply that also if you don't mind the premium they charge.
without any of the other parts of the equation considered, the Holley mounts work well, have good instructions and are a quality product.
8
81cutlass
2,013
Western MN
The holley kit works well but is engineered to make holley money. If you want a drop in solution its a good option, but there are other ways to do it that will save money.
My favorite I have seen is
CTS-V oil pan
Spohn swap mounts
4th gen F body block mounts
Stock pickup accessories
Allows stock AC pump location which is a huge win.
The speed engineering G body LS swap headers work well in that application from what I understand. Stainless too.
https://gbodyforum.com/threads/the-winning-ls-swap-combination-which-parts.73006/#post-692767
X
xcookpac
Mar 15, 2012
72
8
CTS-V oil pan
Spohn swap mounts
Thank you for your input. This is exactly what I am looking for (repurposing existing stock equipment combined with some aftermarket equipement).
GroceryGetter83
GroceryGetter83
238
Tampa, Florida
CTS-V oil pan
Spohn swap mounts
The Spohn guys were great to work with. (y)
