what kind of .40 pistons will i need if my vortec heads are 68cc?
chevy 400 block .040
250 vortec heads 2.02 valves
stock 400 crank 3.750
gbondo57 said:Food for thought. IF you polish the combustion chambers, and smooth radius the edges at the deck surface, C/R won't matter on pump gas. Sharp edges and corners in the chamber/on the piston cause deiseling. I have a happy customer with a 327/11.5:1 no noise. You can buy a 6500 rpm mech pump. Moroso makes a liteweight pump pushrod for extra reliability. I fed a tunnel ram with 2 390 cfm holleys, no prob.
crotchss said:Also keep in mind that when you are running a set of Vortec heads that the valve lift has to be kept to around .450 to .470 lift, unless the guide height has been cut down, or the valve retainer will smack the top of the valve guide. I build alot of 400 based small blocks and have built a few that were basically the same set-up as yours, all of them made good horsepower with great torque. All of them ran around with cams in the low to mid 230's at .050 duration and around the .480's to .490's for lift. Chevy High Performance built one similar to this a few years back aand called it the Impersonator, it made like 425HP and 529 torque or something. Should move your Monte pretty good.
