crucial118 said:Moates.net toys...
I've been on thirdgen.org, code59.org, google, youtube, everywhere the internet takes me to saturate my mind with this programming stuff. I already have the turbo installed. I'm gonna use the '7730 with the code59. I got a 3-bar map sensor and downloaded the files to TunerPro RT already. Now gotta download it to the ostrich and start emulating. And thanks for letting me hit you up when I get stumped. 😀liquidh8 said:Have you looked around on thirdgen.org? Code 59, you using a '7730? TunerPor RT? you going to turbo it? You PM me whenever. 😀
I thought about the Sanderson's, but they were expensive, so I went with the others. The Sanderson's will make your pipes look better for sure and you shouldn't have a problem with the driver's side hitting your valve cover. I was going to put a ic on later, in the same way as you, but I'm only doing 6-7 lb of boost, so ic isn't needed right now. Figured I'd put the $$$ elsewhere. Fuel delivery is thru stock 3/8 line, 5/16 custom return, walbro 255, 24lb inj. Gonna upgrade to 42lb inj soon. Haven't downloaded the tune to the ecm yet, so I'm not sure how it will run with the starter tune. You might need a bigger carb tho.BuWaGone said:This is crazy but my plan for my hot side is almost exactly like yours. I already got Sanderson CC2 headers but both are like your passenger side header. But I'll have the charge pipe coming toward the front of the car since my wagon will be intercooled and it'll also blow thru a 600 Holley double pumper. I gotta find to time to read your whole thread but how is your fuel delivery?
crucial118 said:I thought about the Sanderson's, but they were expensive, so I went with the others. The Sanderson's will make your pipes look better for sure and you shouldn't have a problem with the driver's side hitting your valve cover. I was going to put a ic on later, in the same way as you, but I'm only doing 6-7 lb of boost, so ic isn't needed right now. Figured I'd put the $$$ elsewhere. Fuel delivery is thru stock 3/8 line, 5/16 custom return, walbro 255, 24lb inj. Gonna upgrade to 42lb inj soon. Haven't downloaded the tune to the ecm yet, so I'm not sure how it will run with the starter tune. You might need a bigger carb tho.BuWaGone said:This is crazy but my plan for my hot side is almost exactly like yours. I already got Sanderson CC2 headers but both are like your passenger side header. But I'll have the charge pipe coming toward the front of the car since my wagon will be intercooled and it'll also blow thru a 600 Holley double pumper. I gotta find to time to read your whole thread but how is your fuel delivery?
