Electric fan whistling
dickeymoore
dickeymoore
486
Atlanta,Georgia
I'm running a Lincoln Mark 8 electric fan on my Griffin radiator with a small block Chevy 400 I have a running his fan for like almost 2 years but now I think I'm hearing a little whistling sound like a teapot Kettle I changed out the alternator but that is not it so could this be the fan and what does it mean if it's a little whistling or is this normal?
pontiacgp
pontiacgp
blank
Mar 31, 2006
27,719
Kitchener, Ontario
bearings dry up, you might want to search to see if this is a common problem with those fans and if there is a fix for them.
Reactions: fleming442
Thread starter Similar threads Forum Replies Date
FluoFerret Electric fan shrouds Cooling / Heating / AC 22
O Electric fan relay Electrical / Ignition / Starting 18
Fishbait17 Electric fan install Electrical / Ignition / Starting 14
Bri guy Electric fan setup Cooling / Heating / AC 33
CaliWagon83 REGAL Electric fans worth it on stock engine? Cooling / Heating / AC 28
84cutspreme stock electric fans Buick Regal / T-Type / Grand National / GNX 2
H 1984- 8? Buick Regal electric question Electrical / Ignition / Starting 1
Spintire47 Lower Radiator hose, Bbc, alumunun radiator, electric water pump How-To's / Knowledge Base 0
buick7332 Help with electric trouble Pontiac Grand Prix/Grand Am/LeMans/Bonneville 4
Bonnewagon Electric power steering General Discussion 6
S wire electric choke General Discussion 14
CDUNIGAN1981 Electric trunk locked, no key, car disassembled Electrical / Ignition / Starting 6
Spintire47 Electric water pump conversion G-Body Racing 2
HAFROD Electric trunk release installation tips Electrical / Ignition / Starting 2
S Electric windows? Electrical / Ignition / Starting 15
H Electric locks Body / Trim / Paint / Glass 0
565bbchevy Rimac Concept 2 Electric Hypercar General Discussion 3
M No Brake Lights! Electrical / Ignition / Starting 7
Doug213xrj electric cooling fans stopped working Cooling / Heating / AC 5
Bri guy electric choke wiring Fuel / Air / Boost / Emissions 67
JAMCAR223 Electric fuel pump mounting ideas?? General Discussion 10
Dayzedandkonfuzed BBC Electric water pump... How to get coolant to the heater core? Cooling / Heating / AC 6
B SS fan New Users 4
M New member, longtime g-body fan New Users 6
A Help with fan & fan clutch Chevrolet Monte Carlo / SS / Malibu 4
Rudy913 7 blade fan General Discussion 25
Longroof79 Fan belts -cogged vs. smooth General Discussion 14
SmokinJoe cutlass supreme upper radiator hose strap to fan shroud Oldsmobile Cutlass / 442 / Hurst/Olds 6
Chuck Cole Oldsmobile V8 Fan Shroud General Discussion 7
pontiacgp Cooling Fan Switch Probe General Discussion 6
olds307 and 403 Best thread in fan switch Cooling / Heating / AC 15
8 GN cooling fan won’t turn on Buick Regal / T-Type / Grand National / GNX 9
MrSony 7 blade fan good upgrade? General Discussion 95
pagrunt Storage of a good fan clutch for future reinstall Cooling / Heating / AC 5
olds307 and 403 Glad I am not a chevorlet fan or this would come home. General Discussion 8
Lukeschwtz 86 442 GM fan belt part number General Discussion 8
Dsmooth7 Need help!!! Car was whistling popped the hood and found this.... Fuel / Air / Boost / Emissions 5
Similar threads
