This would be for my 86' Regal, so do I remove a fuse to plug it in or do you use a specific accessory port?It plugs into the fuse box, and you ground the unit with a lug under a dash screw, very easy to install or remove.
I would urge caution using a generic Boost module, and it would require cutting harnesses, etc, but knock yourself out! It's only a hobby, right?
Cheers!
Howie
Cheers!
Howie
