I finally got around to fixing the slow passenger side power window in my Monte.
I had new motors from Cardone,part # 82-144,they do not come with brackets so you need to re-use the old ones.
I got the new one in relatively rouble free and tried it and could see a difference right away.
Then I put the LMC HD window harness in and it made a big difference also,although for some reason the window only works with the drivers side switch and not the passenger side switch.
All in all I am quite pleased with how the passenger side window goes up and down now.I am putting the Monte away in winter storage this weekend so the drivers side will be on next years "To Do"list.
I also lubed the regulator,track and motor gear real good with some white lithium spray grease,and while I had the door panels off I made sure all the fasteners were tight and I snugged up the pads that hold the window tight.
Guy
Guy
