Fast Power Windows?
GuysMonteSS
1,449
1,543
Kentville,Nova Scotia,Canada
I finally got around to fixing the slow passenger side power window in my Monte.
I had new motors from Cardone,part # 82-144,they do not come with brackets so you need to re-use the old ones.
I got the new one in relatively rouble free and tried it and could see a difference right away.
Then I put the LMC HD window harness in and it made a big difference also,although for some reason the window only works with the drivers side switch and not the passenger side switch.
All in all I am quite pleased with how the passenger side window goes up and down now.I am putting the Monte away in winter storage this weekend so the drivers side will be on next years "To Do"list.
I also lubed the regulator,track and motor gear real good with some white lithium spray grease,and while I had the door panels off I made sure all the fasteners were tight and I snugged up the pads that hold the window tight.
Guy
20,399
Guy
if the window works with only the drivers side switch and you have power to the passenger side switch that means the wiring is good, the contacts in the passenger switch are either dirty or worn
GuysMonteSS
1,449
1,543
That will be on next years to do list,LOL
Going for one more drive today then its storage time tomorrow...
Guy
GuysMonteSS
1,449
1,543
Well I got back to this project today.
I took the passenger door panels off and tried two switches,one the old one and a brand new one from Mikes Montes.
Neither one would power the window up or down,but it still works from the drivers door switch.
I also soldered most of the butt connector conections for a better job.
I have no idea why the passenger door switch will not work,but I was getting frustrated so I put it back together...
Guy
20,399
Guy
would say it the problem is probably the pink power wire on the RH switch....
GuysMonteSS
1,449
1,543
Thanks Steve,but I found that diagram in my shop manual and there is power at the pink wire.
I may be able to strip another switch and connector from a B Body Pontiac Parisienne and try that.
Guy
20,399
You tried 2 switches and you have power so the issue must be in the plug that the switch plugs into. That diagram does not show it but there is a ground that goes to the switch. That could be the problem.
GuysMonteSS
1,449
1,543
Thanks Steve,there are two what I thought were un-used terminals in that plug,maybe the ground broke off and I didnt realise it.
I will have a closer look,hopefully today,and I will update you at that time !!
The new motor and LMC harness sure made a big difference in how fast the window goes up and down now,it was dead slow before.
Guy
20,399
When I had a problem with mine last year I took the plug apart and tried to find new terminals so I could repair the plug. I found the terminals online but they were not available and they are still not available. I ended up heading to the recycling yard to get a "new" plug.
http://www.qualitydist.net/pico-5846pt.html
pico-5846pt-16-14-awg-gm-power-window-and-door-locks-universal-terminals-2965880-5-per-package-5.jpg
mclellan83
4,302
9,588
Pgh, PA
Did you do the HD kit with the auto feature? I bought the setup from a member on the MCSS board and never got around to installing it partially because the seller has continually "forgot" to send me the instructions
