CURRENT 6.0/4l80E swap parts = $$$$
FastCraig
407
594
Huntington, WV
Got a reply back from Comp Cams with their recommendation of an XFI cam,
Hyd Roller - 2100-7200rpm - Dur. At 0.050 222/236 - Valve Lift 0.566/0.578 - 114
. IDK if this is what I want or not. It "greatly improves mid to top end without hurting bottom end". I think I want a "greatly improves bottom to mid without hurting top end"...…………..
Jonathan Martin <[email protected]>
Fri 6/21/2019 9:28 AM
    • You;
    • Comp Cams
Hi Craig,
I would recommend part # 189-403-13.
Also considering:
  • BRIAN TOOLEY RACING BTR TRUCK STAGE 3 CAM Spring and Pushrod KIT
  • Stage III Camshaft Specs (31824133): 218/224 .553/.553 113+3 Requires a 3 bolt timing gear.
Also considering: Texas Speed TSP 228R 228/228 .600"/.600" 112 LSA
Also considering: Summit 8713, Stage 3 LS Truck Swap Cam, 222/231 112+5, .545/.545 Lift, 3-bolt
What are your opinions on these 4 cams? All 4 would fit with my desired 2800 stall TQ.
Northernregal
Sloppy McRodbender
Oct 24, 2017
3,359
12,828
Red Deer, Northern Montana territory
Summit or BTR. You dont need lift in an LS motor to get flow and your valve train will be happier. Summit will probably be cheaper and I think you could go with some GMPP springs, also save the $$$.
64nailhead
Goat Herder
Dec 1, 2014
5,710
12,219
Upstate NY
I like the comp cam spec you listed for a daily driver. 226 isn’t duration with 114 lsa on the 111 icl is going to drive pretty well in a 6.0. And I agree completely with Northern Regal about the lift. At lower rpms, the additional .080-.100 of lift does nothing other than wear out your valve train quicker imo.
FastCraig
407
594
Huntington, WV
Updated my parts list. Some major changes from the original list. No longer going with the 6l80 and instead a Stage 2 4l80 with a 2800 converter. That should work nicely with the Summit Racing Cam. I'm reluctantly eliminating VVT. After much research and feedback the Summit cam seems like a great fit for what I want. No price listed for a tune, or a tuner yet. I'll look more into that after the engine gets pulled. The 4l80 is out of an 07 3500 van. Not sure how to alter my harness yet to accommodate the 4l80. I may end up buying one after all. I pick my transmission up tomorrow. Finally feel like it's really going to happen.
Hooker full length Blackheart ceramic header swap kit. Now $1473.88...…..Was $1350.99.
07 4L80 trans, rebuilt $1000.00
PATC Power Raptor 2800 stall converter. $465.00.
Summit
Level 1 SUM-8714 Stage 4 Vortec Truck Swap Cam and Beehive spring kit: 226/230 112 +4, .545/.545 $393.17
TCI shifter cable. $69.00
Trick Flow VVT delete kit $209.99
TOTAL. $3411.04
FastCraig
407
594
Huntington, WV
4L80E-S PN- 24009421
