Holley Sniper EFI. Who’s running one, any opinions, tuning?
20,397
Sorry. My spelling and grammar is horrible and I have worked a lot lately. I have been very tired at night. Don't mean to make excuses, sorry I will try harder next time boss. As for the problem. Pressure sounds like it is ok. What type of fuel lines are you running? Could be a flow issue? Also could be a timing issue also. Hope it runs better for you now.
1983calais
278
337
Tiffin, OH
I think Zach thought pontiacgp was me asking the question. I’m running the stock fuel line from the front to rear with 3/8 fuel injection hose with -6 an fittings. I am going to play with the timing some. Since I reset the EFI and adjusted my timing it runs much better. I plan on driving it some this weekend and see what happens.
20,397
I thought I was too...I think Zach needs some sleep....
5,711
12,223
I can't remember if your timing is computer controlled or whether you have an old school HEI, but it doesn't matter so I'm feeling too lazy to go back and read (alot of late nights here as well, and happy about them:) ).
When you want to get your timing under control there is an easy way to do it. If you're using an HEI, 1st, unhook and plug the vacuum advance line, 2nd, set the base to 15-18 and the mechanical advance + base, often called 'all in' to 34 degrees at 3000 rpm's. Make sure that 'all in' doesn't get any higher by revving to 4000-4500 rpm's to confirm that it stays at 34. Then go drive it like you stole it and tune your fuel from there. DO NOT tune for highway cruising speeds - YET. Once you get the stumbles, backfires, lean spots, rich spots tuned out of it, then tune the timing for WOT pulls for maximum performance. It might take another 2-5 degrees of 'all in' depending on your cam, compression, car weight, converter slipperyness, etc. Once this is done, now tune the timing for idle, cold and hot startup and highway driving with the vacuum advance.
If your timing is controlled with a computer 2 dimensional table, then do the same across the bottom at every cell below idle Map across the entire rpm range (15ish degrees), and then everything above 3000 rpms to 34 degrees and autoscale down to 1000 rpms or idle speed. In a nutshell, have the timing only change with RPM starting at 15 at idle and ending at 34 at 3000 rpms and above.
If you are unclear, then let me know and I'll attach a pic of a timing table setup like this. Doing this WILL NOT hurt your motor in any way shape or form. It will not get best fuel economy and might not idle at the coolest possible intake and coolant temps, but it will work and will allow you to straighten out your fuel/AFR.
If you can appreciate, the Megasquirt manuals recommend doing this with all auto/self tuning functions turned off so that you can get a base fuel and timing table that doesn't require crazy amounts of correction. The Holley has one thing that makes the selftuning function work better than an MS. I can explain if you'd like, but it might muddy up the waters for what you have going on.
Lastly, and I should have said this earlier, you need to confirm that your TDC mark for #1 is inside of a degree or two of precise. This has to be done on every motor, whether old school carb and points, or an LS7 or modern computer controlled Hemi.
Mills
n00b
Jun 13, 2020
So I have the Holley sniper throttle body on the 327 in my mcss with a t5 behind it. Almost every time I drive it, it acts different. I have probably 700 miles on it in 3 years and it isn’t what I thought it would be so far. Im not giving up on it but there is no consistency. Last couple times I drove it, it wasn’t to bad. I drove it yesterday and every time I went to take off from a stop, it would want to die, spit, sputter, and pop. Pissed me off. So I pushed the clutch in and revved it to about 7000 and then it ran fine for about two more take offs from stop lights. Then back to the crap. Who is running one, any opinions, or who knows anything about them? Thanks everyone.
Have you checked the o2 system that tell the computer how much fuel to add sound like it lean
Fenderbender
19
15
Northern Wisconsin
I believe that you said that your O2 sensor was installed in the header collector, Holley recommends that the O2 sensor be installed after the header collector.
1983calais
278
337
Tiffin, OH
Great info 64! This is my next step to experiment with the timing. I believe it is close as it is running better but I will adjust it like you said and report back.
1983calais
278
337
Tiffin, OH
I’m pretty sure that the instructions said in the header collector but I will go back through the book and check.
20,397
from the instructions....
"If you have long tube headers, mount the sensor approximately 6-10” after the collector."
