Hot or Not
icr242005
Mar 3, 2018
53
16
I’m going to do a WOT run when the weather straightens out around here. 383 stroker, AFR210 head, 640 lift, 1 3/4 down tubes, 3” all the way back, all roller 10.7:1, 93 octane pump gas up to 5% to 7% ethanol blended fuel. Holley 4150/750. Here’s what I don’t like, pulled jets last night and they are 68 on all four corners. Will be bumping up on secondary’s tonight. Thoughts on spread of jets
bracketchev1221
1,416
1,654
If the carburetor has a power valve front and back, its generally the same front and back. If there is a plug in the rear, anywhere from 6-10 is the spread. I usually start at 8 and go from there. My dominator on my 565 was square jetted with no power valves in it.
Macguyver
SOUTHSIDE MACHINE PERFORMANCE
GBodyForum Sponsor
Mar 21, 2017
292
458
Time for a small investment of a wide-band O2 sensor and gauge only to complement the time and money you have in your respectable engine build. You need proper AFR at all throttle positions.
Tuffregal83
639
1,150
Lockport, Il
Same one I used and in the back of my Regal Haynes manual lol
denny
279
116
i think they look great. most of my old career mechanics say it is almost impossible to read plugs these days with all the additives in the gas now.
