How to swap different types of rears into G-bodies
gnvair
1,067
1,227
Not great for drag. Better at pretty much everything else.
The 99-04 Cobra IRS was a by design, a compromised set up as they were designed to fit within the set confines of the existing Mustang platform. I knew guys who autocrossed them and the geometry was not ideal. A well set up solid axle Mustang does much better than they do with the 99-04 irs. About the only thing they do better is ride quality.
Macguyver
SOUTHSIDE MACHINE PERFORMANCE
GBodyForum Sponsor
Mar 21, 2017
292
456
Macguyver
GBodyForum Sponsor
Mar 21, 2017
292
456
pagrunt
8,952
14,837
Elderton, Pa
Is there anything that was designed that way by chevy. Like an IRS afterthought that could more-or-less bolt in on the GBody? like a corvette reared or a cobra rearend?
I'm not familiar with the Mustang set up. But the idea of adapting a C2/C3 design into something that looks & functions as if it was on the drawling board in the early-mid '70's is what I have thought of over the years. Working it into a bolt in cradle that doesn't clutter up the what could be usable space is one thing I would try. Then trying to figure out a mono leaf, coil overs or just regular coils/shocks. Besides using the control arm mounts use the coil pockets to be used for additional mounting points. One issue I can't figure out what kind a exhaust clearance would there be. Wish I had the drawling skills to try to draw it up.
81cutlass
4,599
13,343
Western MN
If you can find a dana 44 manual c4 rear suspension it might work, but swapping in an auto dana 35 center section is worthless.
I have seen people IRS swap 4th gen F bodies but what do you get when you swap a 99 z28 t56 ls1 camaro? A corvette.
GroceryGetter83
LS Mafia
672
2,342
Tampa, Florida
I'm excited to get this under the car
