Ok I'm beat! Without a good 37 degree flaring tool, i cannot run my lines how I want. 😢 I'm ordering a SS -3an flex tube. Off hand, (without me getting to my car and measuring. my car is not here, its across town.) Does any one know the length I should use? the choices are, 21 inch and 30 inch. Thanks in advance.
T
are the fittings on the throw out bearing 4 an?. To go from your master cylinder to the throw out bearing you'll need the 30"...21" might fit but it will be tight
but if you do want to make your own lines you can get an AN flaring tool...
I was thinking 4 an cause all the ones we use in the race car are 4 and the Howe's I used was 4 an. I'm apparently out of the loop on the new cars so I never figured you could use the adapter in the throw out bearing...it might have saved me some money if I was up to date case the Howe throw out bearings are $180 up here in Canada
I was saving money also, My transmission came with the stock H T/O bearing and shifter from the salvage yard. So i made it work. But It was a hassle. I should have got a new one, bc now its leaking from the internal seal. 😢 I got one good disengagement and that was it. I'm seriously thinking of going your route. The only issue with that is finding a early bearing retainer. I haven't seen one yet. Everything is for the Mustang. Any ideas? I'm kinda lost.
Have you checked to see if you can get a seal kit for the throw out bearing you have? Another thing is is there was too much clearance or if the pedal travel was too great the bearing may have been over extended. If your looking for a Howe throw out bearing like I used this is it. ...
Thats the one i saw for 140. But finding a early stock bearing retainer to mount it is proving to be difficult. I'm probably gonna just replace the the stock bearing if i don't find a retainer.
What do you mean by early bearing retainer? I have 4 T5 WC's from the 3rd gen F body. If you want a bearing retainer from one of them let me know, I'll be happy to send you one. There are also steel aftermarket retainers that add strength to the casing.
I meant that since my T-5 is the last that GM used and was on a 4th gen F-body. It never had a traditional bearing retainer. So I'm weary that the older one fits correctly since i had to make so many mods. Thanks for the offer, i plan on getting another T-5 from a 3rd gen and that will use a Howe. Plus I'm curious to see the comparisons between them up close.
