Usually when this happens its a bad driver in the ignition control module. Check the wires and the connector that plug into module. If all is well then replace module. Sometimes it is the ecm but very rarely.
I'll check the connections, and I took the module in & it tested as good.
I read a couple places it could be the pick-up coil...any thought on that?
And thank you for your replies.
