Issues after turn signal switch replacement
RegMan79
Feb 23, 2016
60
2
8
36
Tucson, AZ
Hello, 79 Monte. Just replaced my turn signal switch only to find out that wasn't the problem anyway. It's where the lever connects to the metal linkage that goes to turn signal switch. It's busted where leakage meets lever basically. Had the car for about 2 months now and from what I understand somebody tried to steal it and messed up a bunch of the stuff in there. Is this fixable?
Next, when I turn the car on the passenger side parking light up front and the rear tail light stay on. When I turn the parking lights or the lights on they function normally. There's also one green light on the dashboard which is the turn signal light (green right hand side) stays on constantly. When I went out this morning to check to see if it was still doing it, it was so I took the car out for a second and then stop doing it so it's intermittent. Maybe a bad TSS? Any ideas? Thanks.
yes its probably fixable. In my experience if a column was butchered in a theft attempt then swapping it out was easier than repair.
Great thread here I have had bookmarked for a while about digging into the column.
http://www.elcaminocentral.com/showthread.php?t=27192&highlight=tilt+column+repair
Your lights sounds like something is crossed. Did you change or move any bulbs ? I know the plug on my tail light is pretty worn and if you put the bulb in backwards it feeds power back thru the ground light up other lights on the car ( ei: left light flashes and the parking lights in the rear flash as well ). I assume they all functioned fine before you opened up your column ?
Yeah they all functioned normally. It seemed to have sorted itself out for now. The part I'm wondering if it's replaceable is where the metal linkage meets the turn signal lever. Can't seem to upload the picture.
