What 455?
in one of your other threads about your engine..Jared mentioned it in his post above #106. lilbowtie found you a Buick 455 close to you on craigslist
What 455?
I've been at this for a long time. Even with me doing my own work (Cam bearings, removing-installing rods, heads ) I can tell your going to have bundle of cash in this motor. Maybe you might want to take the same route you did on your trans. Here's an upgrade option and located just north of you.
455 Buick - $1 (Nevada) hide this posting unhide
< image 2 of 4 >
QR Code Link to This Post
Rebuilt early 70's 455 Buick, carb to pan, $600.00obo.
What mounts did you use? What transmission did you have?I had a Buick 455 in an 86 cutlass with the same springs and rear. Iirc Buick big blocks are the lightest big blocks
what motor side mounts?Was actually on stock 307 olds frame mounts. But would have bolted to the stock 231 mounts in my other cutlass. Had a th400 but if I did it again I'd go th350
