Manual Trans. with cruise?
7,989
18,702
Did any of the factory manual transmission a/g body cars come with cruise control? I ask because I am going to run mechanical clutch linkage for my T5 swap and intend to run cruise control. My car came from the factory with cruise but the previous owner removed the cruise control harness to make room for the clutch pedal rod. Evidently the cruise/auto cars used the same hole in the firewall to pass the cruise wiring through that the manual trans cars used for the clutch pedal rod. So the question is, if cars came from the factory with both manual transmission and cruise control, where was the cruise wiring routed through the firewall? I bought a NOS g body cruise control kit, still in the box so I will figure something out, even if it means drilling a new hole in the firewall but I would prefer to emulate what the factory did if there ever was such a thing as a manual trans g body with cruise control.
9,194
15,446
Wasn't offered due to the clutch rod & cruise control harness/vac line used the same firewall hole.
L67ss
1,350
420
Mebbe drill a hole next to it to emulate factory?
marcar1993
702
209
New Jersey
That's what I'd do too... Just make a hole near the factory one, it doesn't need to be nearly as big either... the factory harness is like 4 wires and a vacuum line and the hole is like 1 1/2"!
UNGN
3,048
3,264
Southlake, TX
My '79 GP had aftermarket cruise control. Back in the late 70's/early '80's there were shops that specialized in installing aftermarket cruise, A/C and power sunroofs. By the late 80's/early 90's when these once rare options became std or widespread a lot of these shops went away.
7,989
18,702
driving a stick is too much fun to use cruise control.....:D
Yes but I want to keep my Brougham loaded, just like I want to keep it all GM!
GP403
Administrator
Site Admin
Feb 25, 2005
4,514
4,929
Rolla, MO
hm, I'll have to look and see how mine is set up. The original cruise is there, and it used to work once upon a time... not sure how its routed though. I also don't think it would cut out if you depressed the clutch, so there's that..... Honestly its been down so long I don't remember :(
  • Optimistic
UNGN
3,048
3,264
Southlake, TX
I'm pretty sure my aftermarket cruise didn't cut out when I pressed in the clutch. The 301's valves floated about 5300 rpm so it wasn't like the motor was going to grenade, though.
