Hey all. My SBB seems to have a main cap bolt that is missing. I have 9/10 which as you can imagine is very irritating. The last thing I need is to spend 100$ on NEW fasteners, then turn around get the block off of the stand again, and have the mains align honed for another 100 or so, when money is already tight.\ (Working on a 7.25/hr budget here.) I really do not want to have to go through all that. Would I just be able to get some old/OEM bolts off of ebay or something and use those without issue if I can't find the missing bolt? ALSO, how do I know what order the caps go in on a 1977 Buick 350? It's obvious for the front and rear, but the three inners I have no idea. This engine will not make over 300hp to the crank. Not a high spec runner, just a mostly stock rebuild. Slightly better cam, bored 30 over, heads being cleaned up, etc.
Any help is appreciated.
