Yesterday was my day off work and the weather was beautiful, so I spent most of the day outside working on the car. I began modifying the wiring harness, installed the last two sensors, then routed and installed most of the harness. I finally found two radiator hoses which could be sufficiently modified to fit my application. I also found two heater hoses, each with a pre-formed bend to facilitate attaching them to the intake and the water pump. Then Mike showed up, taught me how to rebuild the Edelbrock carburetor he loaned me, and we installed that. He had a drop base air cleaner lying around, so he massaged it with a hammer to make it fit over the carb. It looks like a 3" air filter will fit under my closed hood (perhaps requiring me to remove a few spots of the support braces), which amazed us both.
It's starting to look like an actual engine:
The heater hoses were... interesting. As some of you know, the big block Chevy engine has a small piece of heater hose (the water pump bypass hose, I think it is called) going from the intake manifold coolant crossover down to the water pump. On my AirGap manifold and aftermarket water pump, these two hose barbs don't come anywhere close to aiming at each other. I made a couple parts store runs, trying to find some goofy pre-bent hose that might connect the two, but no luck. So we decided to get creative. My intake coolant crossover has two outlet barbs on it; who says the one pointing forward has to connect to the water pump? I decided to instead route that intake hose barb to the heater core. The barb that points up and usually routes to the heater core would now be used to connect to my water pump... and I found a pre-bent hose that actually connects the two.
I admit, the hose area looks a bit... busy. You know, because Roadkill.
Soon.
Soon.
