Don't put your finger in the hole, just over it. Don't put a paper towel or anything in there either, it can get sucked in on the downstroke. Take the driver's side valve cover off. Get the #1 cylinder (usually the driver's side front-most cylinder) on the compression stroke. It will be after the intake valve closes but before the exhaust valve opens. If you don't know which valve is which, the exhaust valve will be almost directly inline with the front most port of the exhaust manifold. Intake of course will be the next closest one to it. The exhaust valve will most likely be the one closest to the front of the engine.
(picture)
4 stroke engines operate as such:
Suck (Intake)
Squeeze (compression)
Bang (ignition)
Blow (exhaust)
in that order.
The rotor tang (metal bit) needs to be either pointing directly at, or on it's way to pointing to whatever terminal the #1 sparkplug wire is attached to. If the rotor isn't pointing to it, take the distributor out and reposition it. You may need to stick a long screwdriver down the hole to turn the oil pump drive shaft so it will drop in. The gears are helical cut, so it will turn while putting it in. Put it in a little before #1 and it should shift and face #1 dead on.
Providing it runs after that, you may need to change some spark plug wires around again. Make sure #1 wire goes to #1 terminal, and follow the firing order, 18436572 CLOCKWISE around the cap. It's a small block chevy, so it uses damn near the same firing order as almost every v8 Chevrolet.
Might loose it.Why not?
Considering your finger won't go in as far as the spark plug (size matters?), I think it is perfectly safe.Might loose it.
Might smell a bit worse than before you put it in.
Not that we're far enough down the list to get to it yet, but, always have them good ol nylon gear teeth.he said the car was running and he changed the plug wires one by one so timing should not be the issue...
