No start/no dash lights
80elky
80elky
30
8
So the other day I was replacing the wiper motor on my 80 el camino and when I got done I tested it and it worked fine, so I turned the key off. A little bit later I tried to start it and nothing happened, no dash lights or radio or anything. The battery is brand new and fully charged, the alternator is brand new, I got the starter tested and it was fine. I tested some of the fuses on the panel and got power to the courtesy lamp and such but none of the others. I suspect the ignition switch or a faulty wire somewhere. Has anyone had a similar issue and how would I test the ignition switch?
8
81Regal
1,386
83
Terril Iowa
Check the fusable link at the starter.
Reactions: pagrunt and TURNA
TURNA
TURNA
Rocket Powered Basset Hound
Jul 24, 2009
11,004
Socialist NY
Right underneath the wiper motor is the rear of the fuse panel.
You may have nicked something. start jiggling wires and see if u get power back
If not I would agree with 81Regal
8
81Regal
1,386
83
Terril Iowa
That is only 1 of the wires, another goes to the fuseblock/ignition switch.
pontiacgp
pontiacgp
blank
Mar 31, 2006
27,736
Kitchener, Ontario
it takes alot to burn a fusible link, I would remove the wiper motor to have a good look at the wiring to the fuse block
80elky
80elky
30
8
I have three wires leaving the starter, one is a thick red one, a brownish/beige one, and a black one. The brown one wasn't even hooked up to anything, the red one ran to the fuse box and I don't know where the black one goes. Sorry I know I'm making this a little difficult but the guy who owned it before me swapped the engine and the wiring is kind of a mess so it's hard to work through.
pontiacgp
pontiacgp
blank
Mar 31, 2006
27,736
Kitchener, Ontario
1 fusible link red wire goes to the fuse box, the other fusible link red wire goes to the alternator
8
81Regal
1,386
83
Terril Iowa
The black one is likely the purple wire that feeds power to the starter solenoid.
8
81Regal
1,386
83
Terril Iowa
This might help
Thread starter Similar threads Forum Replies Date
1 1988 Monte Carlo SS won't start Electrical / Ignition / Starting 29
Emhendo Car Won't Start. Battery or Starter? General Discussion 11
08Malibu 97 Yukon no start Non-G Projects 22
9 1981 Grand Prix lj v6 no start Pontiac Grand Prix/Grand Am/LeMans/Bonneville 68
kygaca Car Won't Start Fuel / Air / Boost / Emissions 15
Myles VERY rough idle, hard start, getting worse need help General Discussion 8
Gonzo1970 AC Step-By-Step or Where to Start? Cooling / Heating / AC 53
Rigo’s87 Cutlass won’t start **Help! Electrical / Ignition / Starting 28
lyndon Car won’t start after install of forward light harness Electrical / Ignition / Starting 2
69hurstolds 2020 Corvette to START at $59,995.00 (price updated) OFF TOPIC 102
azmusclecar ARGH! Why won't my tach reset to ZERO after each start? It seems to keep 500 or so rpms. Electrical / Ignition / Starting 10
joesregalproject Start hoarding aircraft stripper General Discussion 13
DSM GRAND PRIX Right side remote mirror dash bezel Wanted 0
C Console and dash Wanted 0
P Gauges dash G-Body Parts For Sale / Trade 0
A MONTE CARLO Check Engine light Chevrolet Monte Carlo / SS / Malibu 2
C Dash stops working Electrical / Ignition / Starting 1
Dktalee Cutlass Dash Insert Overlays General Discussion 2
Dwight Herlick Gbody dash lights pig tails! General Discussion 4
S recovering your dash General Discussion 10
rogus Hard wiring dash Interior 12
T CUTLASS Dash New Users 3
WanaBa442 Ralleye dash with column shift? Oldsmobile Cutlass / 442 / Hurst/Olds 3
CDUNIGAN1981 79 Grand Prix Dash Removal Pontiac Grand Prix/Grand Am/LeMans/Bonneville 10
K CUTLASS Dash install kit Electrical / Ignition / Starting 1
Caper Dash change out Interior 4
HAFROD Another dash vents not working question Cooling / Heating / AC 6
S Wires Interior 7
airboatgreg Dash project General Discussion 6
TURNA What do you use on your dash?? Interior 17
bradswarwagon Dash gauge cluster Interior 3
HAFROD 1978-1987 Regal, Century, wagon, Grand National, etc. Chrome dash insert fix Interior 5
S CUTLASS Brown wire under dash is broken Electrical / Ignition / Starting 0
MrSony Finally! New Chrome Dash Strip 78-87 Regals. General Discussion 0
85ss/85gn 81 Malibu wagon dash trim Wagons! 2
B Dash vent actuator Cooling / Heating / AC 4
Bruce Compton AFTERMARKET DASH Restoration 6
8 MONTE CARLO Which dash kit to use for aftermarket radio? Interior 4
hangar401 Calais dash Lights Oldsmobile Cutlass / 442 / Hurst/Olds 0
TURNA Cutlass dash speaker grills? Interior 17
S Dashtop dash cap install - I give this brand a thumbs up Interior 7
H EL CAMINO Missing a ground some where. Electrical / Ignition / Starting 6
FastCraig Digital dash Dakota vs Intellitronix General Discussion 20
hvyhitr Dash lights General Discussion 2
wskirvin CUTLASS Dash emblems Interior 3
xitabl442 442 Dash ground location? Electrical / Ignition / Starting 1
JCutlass 88 Dakota Digital Dash Interior 1
M Top of the dash is starting to crack Interior 26
nickonometry tinted lights, euro cutlass Oldsmobile Cutlass / 442 / Hurst/Olds 14
blackbuck350 LED lights Electrical / Ignition / Starting 7
Similar threads
