BUILD THREAD Project long time coming
scoti
1,986
3,423
Texas
Oh wow. Is there any chance you could snap some pics when you get a chance so I can show my engine guy?
You should go through his entire build thread. There are multiple images of his exhaust set-up that you can save to share w/your engine guy. There's also a lot of additional info to be taken advantage of for anyone doing an LS swap.
scoti
1,986
3,423
Texas
scoti thanks for the heads up. I found this valve. It goes in both lines. When you're supplying vacuum, it bypasses the heater core and returns coolant thru the other hose back to the water pump. Guess this is/was a common thing. This one was originally for late 90's Suburban.
Part #15-5533
TTT w/this info..... Do you recall the manufacturer? I met a guy @ our local cruise/burger/beer joint tonight w/a clean 79 LS swapped wagon. He was using a shut-off valve & I spoke to him about these but didn't have an image for him to look at. I got his number & told him I'd send him a pic but I bet he'd appreciate a pic, p/n, & manufacturer even more. I saved the image & p/n to my phone; just need the manufacturing source if you remember?
ck80
5,743
9,123
Long story short, I didn't do my homework and ended up buying a bunch of stuff that wouldn't work for me.
Well well well... it appears streetbu has earned his streetname.
I dub thee....
Lil' Tynan
Go forth and represent. :LOL:
  • Wow
Streetbu
Know it all, that doesn't
3,748
11,660
Central NY
Haha, ouch! That cuts deep. Pretty harsh for one mistake.
Streetbu
3,748
11,660
Central NY
It's a GM valve, bought it off Amazon. Part # 15-5533.
GM Genuine Parts 15-5533 Heater Water Shut-Off Valve https://www.amazon.com/dp/B000C9DDIA/?tag=gbody-20
ck80
5,743
9,123
:ROFLMAO:
True.
I guess the question is how you reacted to being told the parts wouldn't work. Did you get mad and blame everyone but yourself for the purchase and for not telling you that it wouldn't work ahead of time?
Streetbu
3,748
11,660
Central NY
Haha, no. Definitely my fault. I wanted them so I didn't bother paying attention to what I was reading, and that others had already figured out, then just bought them. Oh well.
I figured it would be better for people to see my mistake, and hopefully they won't make the same one themselves.
Streetbu
3,748
11,660
Central NY
Finished the rear seat delete kit. Finally....
Reactions: 8 users
5,719
12,245
Wow, that looks great. I like the bars straight to the frame/rear crossmember. I struggled to not put them through the speaker area, but common sense overcame me - I can't get much of anyone to ride in the passenger seat, so who the hell is riding in the back seat? But I didn't do the delete so someone can still ride in the center between those two bars.
Did you put anything around the aluminum rings to keep them from rattling/rubbing on the bars and making noise?
