Great work Donovan! Sorry to hear about the windshield but the repairs are coming along very nicely!
Awesome work Donovan, as always. Sorry to hear about the bad deal on the windshield but the car will be that much nicer for it.
My car, being a Brougham, came from the factory with a fender mounted power antenna (standard equipment for the Brougham trim level). My car also has the bulkhead connector for the windshield antenna. I was as surprised to find it as you. It looks to me that all of these early cars were setup for the windshield antenna and then some were fitted with the power antenna option. If I was painting my car, I would eliminate the power antenna, but I'm not.
Things are definitely looking better on the driver's side of the Olds. It really sucks that your "good deal" on the windshield got out of hand like that. I'm curious about what the glass guys thought about Olds Cool and especially the Juggernaut.
He looks it up and down some more, and replies "Its nice."
That's it, nothing more.
OBVIOUSLY not a car person!
Donovan,
Always look forward to your updates, so when will you update us on the drivers side rear quarter ? i swear I'am seeing flash rust happening !
and thank you for taking the time to educate and entertain us.
Dave
I'm digging on the quality of the work when are you going to do mine lol
I'm one of those guys who can't understand why everyone isn't at least a little bit into cars.
Alrighty. Time for the last update for the week.
I had an excellent night out here in the shop tonight. After spot welding on the row of studs in the low area on the sail panel last night, I clamped my sheetmetal vise grips on 3 studs at a time and pulled hard on them while hammering the surrounding areas. I alternated this with using the slide hammer on them, and gradually brought the low area up.
Once I was happy with what I was feeling, I nipped off the studs, and ground the remainders off so I could get a better feeling of how it was. I was liking what I was feeling, so I dressed down the rest of the upper patch welds and finessed the area a bit more with the body hammer.
The sail panel/quarter window/upper quarter panel rust repair on the driver's side is now totally complete!
There's nothing further left to do here now until the filler work starts!
Couple pics:
As compared to before, remember this?
Big difference!
With that now officially under my belt, I turned my attention to preparing to fix the couple small rust areas above the back window. The best way to access this is going to be to remove the trunk lid and sit inside the trunk. This will give me the best way to reach the areas I need to.
The wiring for the lid came out, and the trunk lid itself came off. With that out of the way, I cleaned out all the interior parts I had stored in there, along with the trunk mat. Perfect, lots of room and good access now.
I then geared up and started stripping all the old urethane, seam sealer, paint and primer out of the channel. My preferred method to do this is with this:
That is a "Clean and Strip" wheel for those who are unfamiliar with it. This is DEFINITELY the hot ticket for doing this unpleasant job, I wouldn't even consider attempting it without one.
I use it in Roloc form, with the arbor in my die grinder:
Walmart sells a pedestrian version of this, more geared towards the hobbiest, but this purple baby is the s*%t. It's harder and more aggressive than the Walmartian versions, and it will eat through almost anything in its path. Including skin!
To give you an idea of what it can do,
Here's a before pic of the channel with the glass out:
Here's the exact same area, after spending 45 mins or so with the wheel:
Nice clean, shiny bare metal.
Nothing else was used here, only the Clean and Strip wheel. As you can see, it does a phenomenal job of removing pretty much everything in its path. I love it, it's one of my more frequently used materials.
Just don't be afraid to get dirty tho...
...'cause it does create quite the mess!
I still have to spend a little more time on this area before I get to the cutting and welding, the bottom ledge still needs to be cleaned up with the wheel, and I'll have to remove the last inaccessible bits with a burr. But once that's done, I'm onto getting the rust above the window looked after.
That's it for the next couple days everyone, thanks for checking back. Have a great weekend, and for our Canadian members, have a happy and safe Canada Day. 150!!
D.
