When sanding runs a sharpie works great as guide coat. I saw it on YouTube and I tried it on a car, and it worked great. When I did that 33 I had to make some blocks for the body lines. I used pvc trim from Home Depot, and it worked great. Great work as always. Can’t wait to see you jump back on the juggernaut.
just got caught back up, haven't been in here as often as I would like lately, been dealing with alot of pain issues that have put me down...
all I can say is wow! love how humble you are when you say sorry for how the interior looks... 😆 looks like it just rolled out of the showroom! love the idea of the headliner material, I had always wondered how it would look on there, and glad I wasn't the only one that thought that. love how you brought the outside shade of grey to the interior to tie it together. as soon as I can get through some of my issues, you've once again got some fire lit under me to get back on some of my junk!
Hope you feel better soon Darin.
You could have left that door as is and simply claimed it was original GM paint. 🙂
Oooh, burn!!!
Looks great, been following on Instagram.
Thanks Jim. Been following your exploits on the mountain garage as well. You’ve been very busy around there this year!
Man, i hope that one day i can get my car to look 1/10th as good as yours! As always D you do a damn good job!
Thank ya brother, appreciate it!
Could of fooled me, looks better than what I'd have if I did it for myself. Still it looks great.
Thank you!
Donovan, great work as always. Also, I have to do the same interior door panel metal strip repair on mine. I have a plastic welder that I bought when I was finishing the silver car. I have to repeat what you did and put that part of that car back together. Those panels look great!
It’s funny, I had actually got out the soldering iron to fix a couple of the clip slots that were cracked...
...and it worked great to fuse the plastic back together when I noticed the metal reinforcement had broken free as well. I scratched my head for a few minutes trying to figure out what to use as a filler rod when I thought of the plastic paint brush idea. It seems to have worked really well, like I said though, just melt the filler plastic into the existing stuff. Or else it just sits on top and won’t actually hold anything.
Of course if you have a plastic welder you’re already 3/4’s of the way there.
Appreciate the kind words!
Turna style:
WHAT ABOUT THE FRONT BUMPER FILLER!!!!!!!!!!!!?
Jared, all joking aside, all I can really say is to be patient and bear with me. I will get to them (almost all of the bumper fillers need refinishing and painting) sometime this winter. I will be the first to admit I’m dragging my heels on getting after them, just simply because they’re such an ignorant material to work with.
But rest assured they WILL be done soon.
Thanks for the Sharpie tip, that’s an interesting one. I’ll have to give it a try sometime. But the purpose of doing the full dry and wet sand was also to completely get rid of all the other deficiencies in the finish that y’all saw. Especially the dirt and dry spray. I want this thing as slick as glass from bumper to bumper, if only to show that it can be done.
Thank you Darin, I appreciate the compliments. The interior is the worst of the car now, it’s a 5 footer for sure. It presents well from a couple feet away, but the closer you get to it the more you can see that needs attention. Although the new carpet and headliner have gone a long ways to start bringing it back around. I have a tear in the side of the driver’s seat that I’d like to get fixed, and I’m rapidly formulating a plan to restore the hard plastic seat backs. They look the worst out of everything now.
Sorry to hear you’ve been unwell lately, I had no idea and wish you all the best in getting it in check and kicking azz again. Take care of yourself my friend.
Donovan I've long been curious how clean the underbelly is on this thing given what you've put into what we can see up top.
Well, I ain’t gonna blow smoke up your azz or sugar coat it, it ain’t perfect. It’s about what I would consider average or maybe slightly above average for its year and our locale. But compared to many of the other G’s I’ve seen guys on here fixing up, I guess it could be considered a cream puff. No holes in the floors, solid rear framerails, no collision or other damage. Mainly just deep(ish) surface rust.
Kinda surprising really considering how bad some of the outer sheetmetal was.
When I had the engine, trans and diff out I tried to be proactive and coated every inch of the frame I could access with POR15. But as of right now the undersides of the floor pans are still untouched. In general, this car was pretty much just neglected and relegated to daily driver status when I got it.
I’ve been slowly replacing and upgrading the major systems and components as I come across them. Engine, transmission, rearend and front steering components have all been gone through and replaced or upgraded, along with the rear suspension. Only the front control arms and the brakes are still untouched from when I bought it, so that ain’t so bad. I will eventually be doing a full rebuild of the front control arms (bushings, ball joints etc), or replacing them entirely with new stock aftermarket ones.
Do you think you will end up removing the body off the frame and doing the full underside with a rust converter and sealer?
Thanks for the welcome distraction from doing my homework. Awesome as always!
It’s highly doubtful. There’s nothing on the underside that’s bad enough to justify the additional work, and this car was never really intended to be a frame off, full resto build. Just another fun and good looking G body to fill the void until The Juggernaut is done.
"Fill the Void"
It has certainly done that. 😁
