BUILD THREAD Project Over The Top - Malibu T-Top Conversion
Jakefromstatefarm
465
923
Wow. You're lower than 25" to the fender lip? That's low....
I think I'm at or below 25", I'll measure when I get the front off jackstands in the next week or so. The rear is 26.75" and I know the front is lower.
I do know that I can't fit a 2x4 (3.5") on it's edge under the cross member.
scoti
1,985
3,421
Texas
Mine is 22ish @ front wheel opening C/L & ~24ish @ the rear. Like I've mentioned.... Others might 'lower' theirs. My stuff is low.
I put a 3" square steel spacer that I use on frame stuff in front of the car in the parking lot. The x-member pushed it around. But, this is why my 25" tall front tires ate through the plastic inner fender-well tops after about 3k miles & why I found asphalt crumbs scattered/remaining in areas possible. It's dug into the road surface on many occasions. The ride is fine as long as the road surface is.
The set-up was just initial to get it going & eliminate the 'grandma' appearance to more of a 'bad-arse Grand-Pop' vibe. Mission accomplished 101%. Now I'm accumulating the parts for better braking + geometry which will also change the height as part of the plan. The 2" drop spindles go away in exchange for 1" drop. The 25" tall 15" front tires go away in exchange for 25.7" tall 18" tires. The front end should come up an additional 1-1.5" (not quite 1.5" by my calcs so about 4" off the road surface @ the x-member center is my hope). This has been slowed by the necessary installation/modification of taller front wheel tubs. Waiting on spindles now & going to mock up a side to verify dimensions.
superbon54, sorry about muddying up your thread.
superbon54
755
2,440
Wisco
Haha no problem! It may come in useful in a future search on wheel fitment….
superbon54
755
2,440
Wisco
Progress started back up today with fitting the digitails into the tail lights. Removing the lenses was not fun. I bet I consumed 50 dremel cut-off wheels and sprayed myself a couple times with molten plastic.
Some big things are coming this weekend…..
Reactions: 9 users
7,989
18,702
superbon54
755
2,440
Wisco
Ran the harness behind the dash this morning. I have 4 cars worth of harnesses in building from so figuring out some of the wires and connections is um…… let’s say fun.
Also test fitted components to the dash. Just dashes built one off my old core and while the materials and build are high quality, the fitment of stock trim kinda sucks. I had to hog out quite a bit around the radio and hvac controls to get everything to fit. On the plus side, what they did structurally will be much better than factory. With any luck we’ll spray some interior parts tomorrow.
Reactions: 7 users
superbon54
755
2,440
Wisco
Sprayed the dash and related components this morning in oxblood. Bought a quart of ready to spray paint from Dixie Restoration Depot and used a little over a half of a pint for these. By the label it’s a custom PPG mix, and I’ve got to say it sprayed out really nice and I would highly recommend it.
Reactions: 7 users
superbon54
755
2,440
Wisco
Need a little help with this one guys. Where does this connector go to? It’s on the power window harness, drivers side, and has continuity with the spade that goes into the fuse box/bulkhead so it’s hot when the ignition is on. All of the switches and motors are accounted for so I’m stumped……
  • Wow
oldsmobile joe
2,067
3,053
mpls
rear window defogger, power seat? i'll try and check in the morning.
