Look what we have here???? PST wants to give the guys a big shout out at SSBC Performance Brakes for coming on board with our Malibu project.
SSBC has hooked us up with there SPORT TWIN QUICK CHANGE ALUMINUM CALIPER.
2 Piston Hi-Performance D154 Replacement Caliper
Direct bolt-on replacement to O.E. single piston caliper.
Caliper Kit Includes:
(1) SportTwin 38 mm calipers
Banjo Bolts and copper washers
All Necessary Hardware
SSBC Performance Brake Systems gives you Bolt on Performance you cant beat! Our quick change caliper kits are designed to replace your O.E. calipers, fit over your factory rotors, use your factory hoses and fit in most factory wheels! Designed with maximum clamping force and even pressure distribution across the brake pad, you wont believe the difference in braking! SSBC Caliper Kits offer the ultimate braking performance in a compact design. Made from billet aluminum, the kits are coated with a clear anodize for maximum corrosion resistance both internally and externally. Our easy bolt on systems includes grade 8 hardware, installation components, performance brake pads and are made in the USA. Caliper Kits will fit most popular wheels*. Replacement pads are available off the shelf at your local parts store. Try SSBC slotted and plated Big Bite cross drilled rotors for the perfect match. Most kits are available with optional red and black powder coat and polishing.
With all the work that has been done to make this car handle as good as it looks. SSBC has step up and given us the stopping power to complete this build
A must have for any muscle car, pro-touring or not. SSBC's Big Bite Rotors!!!!!!
Precision Drilled holes vent super heated gases, eliminating brake fade.
Precision Turbo slotting maintains a clean pad surface giving you maximum grip and quiet braking.
Quality controlled to ensure every rotor meets and exceeds OE standards
Improved braking in wet weather driving
Cooler operating temperatures ensure maximum friction between the pad and rotor for maximum stopping power.
Upgrade the performance and look of your braking system with our Big Bite cross drilled and slotted rotors. The Precision drilled holes vent super heated gases eliminating brake fade while the Turbo slots maintain a clean pad surface for maximum grip!
