Radiator electric fan combos??
denny
279
116
Is it worth the money to go with a good rad,shroud,and dual electric fans? I'm not going to be racing,just cruising. They seem to want $500.00 more for the shroud,fans and wiring over the cost of a good rad.
i just removed my dual fans from my mild street 350. 3 row copper rad. and installed the factory mech. clutch,7 blade fan, shroud and 160 thermo. elec. fans were ok but in 85-90+ heat it started to bump up a little in stop and go. i agree that the elec. does not work well with the old copper rad. let alone the voltage shock when they turn on. 81 malibu. i just cruise and ring it out on the way home several times. i have converted both my hotrods back to factory cooling systems.
FluoFerret
184
243
Luxembourg
Get a large 2 core aluminum with 1" or larger tubes with good reviews and don't look back.
Is it really such a big difference to copper/brass ones? I googled on Summit Racing and found 3 different models that would be interesting. Could you give me your advice on this?
https://www.summitracing.com/int/parts/fbr-fb163/overview/
https://www.summitracing.com/int/pa...iew/year/1978/make/pontiac/model/grand-lemans
8,826
7,779
I had a Champion 3 core rad in my 88, cooling was so so, 195 to 215 with a 160 thermostat. I had a slightly wider 2 core that did much better. I don't what happened to Summit's rads, they must have changed suppliers, they used to have large 2 core available. Consider this one.https://www.summitracing.com/parts/sum-384002/year/1987/make/oldsmobile/model/cutlass-supreme
Or even better get this one, 4 is better than 3 with small cores.
https://www.summitracing.com/parts/sum-384003/year/1987/make/oldsmobile/model/cutlass-supreme
Or this is the best deal and will cool as well as any of them.
https://www.championradiators.com/American-Eagle-Pontiac-Grand-Am-radiator-shroud-1978-1980
FluoFerret
184
243
Luxembourg
Sounds very interesting. And these should definetly fit into my Lemans.
I found out that Mishimoto has a fitting one and they sell also directly to Europe. Any thoughts on that brand?
8,826
7,779
The reviews look good. Just go with the 3 core minimum. Contact Champion and see what it costs to ship the large 2 core from them. Weigh the costs, warranty and reviews into the purchase. I bought a mini starter from Summit, it was a POS from day one. If I would have read the reviews, I would have bought the Powermaster one for $10 more and saved myself grief.
9,617
12,697
When you are all talking about Intrepid fans fitting, is that using the shrouds from the same vehicle?
They fit the radiator because they have a built in shroud as part of the dual fan set up, you don't use the factory shroud.
Streetbu
Know it all, that doesn't
3,740
11,593
Central NY
I use a stock three core copper radiator and fans from an 93-97 LT1 Camaro. Works great. Gotta make sure you have at least a 100 amp alternator to run electric fans though...
eric_cspan
22
29
13
Cold Case offers a complete kit with 2 rows of 1.25" tubes for around $550. Much less than the big boys out there and the 1.25" tubes makes a world of difference!
Let me know if I can help at all!
FluoFerret
184
243
Luxembourg
Do you have any numbers or documentation on the thermal efficiency for this? I am considering swapping one of those in my car, the problem is, since I live in europe, i don't want to spend a lot of money, just to find myself with a radiator who performs about the same as my heavy duty 3row copper/brass one :( for US-engines, traffic here always means higher operating temperatures, and once my fans switch on at full speed, they rarely switch off during driving...
