Radiator????
Fenderbender
Fenderbender
Northern Wisconsin
Thinking about putting a new radiator in my wagon. It has a fresh 383. What brand does everyone like these days? Thanks!
565bbchevy
565bbchevy
7,424
Michigan
I think a lot of people are running Champion radiators, affordable, decent build quality, all aluminum construction and your choice of 2,3 or 4 rows plus they fit without modifications in your factory shroud.
Here is the 3 row I installed in my Regal project.
84 hennesymonte
84 hennesymonte
33
8
YEAH! thats nice im running electric fans i took that fan you got out and replaced it it gives you so much more room! im trying a 2 row on a 350 sbc it should be cool!
84 hennesymonte
84 hennesymonte
33
8
here is what mine looks like!
565bbchevy
565bbchevy
7,424
Michigan
565bbchevy
565bbchevy
7,424
Michigan
yeah thats sweet it should keep it cold with no problem!
The Intrepid fans cool the 565 with a large Griffen radiator, the Regal is getting a 355 so it's a non issue for that one.
84 hennesymonte
84 hennesymonte
33
8
WHERE DID YOU GET THE RADIATOR BRACKETS TO HOLD IT IN PLACE?
565bbchevy
565bbchevy
7,424
Michigan
I made them out of aluminum and then polished them like I did with the radiator before I installed it.
Thread starter Similar threads Forum Replies Date
Chuck Cole Lower Radiator Hose Size mismatch Ideas? General Discussion 11
M Summit Copper Radiator Cooling / Heating / AC 32
M Radiator Paint General Discussion 7
bobby frillou Whats needed for radiator upgrade v6 to v8 engine General Discussion 2
FluoFerret Electric fan shrouds Cooling / Heating / AC 22
Spintire47 Lower Radiator hose, Bbc, alumunun radiator, electric water pump How-To's / Knowledge Base 0
G 85 Camino radiator G-Body LS Swap 2
olds307 and 403 Installing GN radiator baffles on a 88 Cutlass General Discussion 3
SmokinJoe cutlass supreme upper radiator hose strap to fan shroud Oldsmobile Cutlass / 442 / Hurst/Olds 6
C Its that time of year, radiator season - 2020 edition Cooling / Heating / AC 9
MalibuDavyou5 Oil in the Radiator. Cooling / Heating / AC 33
MalibuDavyou5 Radiator recommendation. Cooling / Heating / AC 8
Jims442 CUTLASS Upper radiator hose engine swap Engine / Swaps / Driveability 16
FastCraig Aluminum Radiator saved me in town General Discussion 13
2 Trans cooler lines leak at radiator Cooling / Heating / AC 5
H MALIBU Silicone radiator hoses New Users 11
B Radiator core support question Frame / Chassis / Suspension / Steering 2
Stupidquestionspro HELP Radiator questions Cooling / Heating / AC 10
S GN Radiator Air Box Kit General Discussion 5
Chuck Cole Cooling /Radiator Question Oldsmobile Cutlass / 442 / Hurst/Olds 28
olds307 and 403 Pictures of air flow deflectors for the radiator General Discussion 42
MechMan Champion Radiator G-Body LS Swap 18
