Agreed Eric. It's photogenic in pics, but looks killer in person!That car looks so good!
I'm by no means an alignment expert but I've read that a slight amount of negative camber helps with handling. UNGN has a lot of experience. I'd probably give his recommendation a try.
U turns? Left turns? Illegal here go right 3 times take a jug handle. Lol no wonder other states think we can't driveMy city went on a beautification project about 8 years ago with their natural gas royalty money. They replaced the continuous, bi-directional left turn lanes on all of the major streets with landscaped concrete dividers, with specific, unidirectional left turns. This meant I could no longer Left turn directly into my neighborhood, but had to drive past the entrance, U-turn a couple blocks up and drive back.
Some of my cars, like my brand new at the time 5.0L Mustang couldn't U-turn without plowing towards the opposite curb every time. Positractions, especially locker rear ends make the plow even worse. A brand new performance car that can't U-turn without plowing straight towards the curb is embarrassing. I bought camber/caster plates and put about 1 negative degree of camber in the mustang and it will U turn on a dime, now.
Thanks Eric. We really appreciate it. It took me about 6 months to get over the shock of the car being that brilliant blue instead of the grey epoxy primer.That car looks so good!
Thanks buddy. I'm really pleased that you and Brian got to see it in person.Agreed Eric. It's photogenic in pics, but looks killer in person!
Thanks man. I was hoping you would chime in. It's obvious you know what you are talking about. Yeah, your ramp idea is good. I'm just glad the Camaro isn't any lower than it is. I was able to get enough of my enormous carcass under the front of the car to get the job done. We will follow up on your recommendation and will adjust the camber to -0.5 to -1.0 degrees. The caster looks ok to you?On all my street cars I set up static Negative camber of -.5 degrees or so. It will reduce understeer and outside tire edge wear, but isn't enough to prematurely wear the insides. The factory positive camber is to make the car plow and the tires squeal so you'll slow down.
I also have ramps made from 2X10's nailed to a pair of 4X4's to make it easier to slide under the car to adjust things. Nothing quite as embarrassing as getting trapped under there by the airdam and trying to wiggle out.
Chris, it's good to have you in here and to hear from you. How is the poor-man's Monte? I miss that thread. I agree with you. UNGN knows what he's talking about. I don't think we'll ever drive the Camaro or my GP as fast as he drives his.I'm by no means an alignment expert but I've read that a slight amount of negative camber helps with handling. UNGN has a lot of experience. I'd probably give his recommendation a try.
