I am champion.... I am the champion.... I am the champion of the world! I bought a new timing light tonight. I checked my static timing and it was way off. Set that up right and had to adjust idle a little bit. I now have a lot more vacuum too. Once I had the engine running pretty good I took it for a spin. Adjusting the kick down cable did nothing. I then popped off the governor cover off the transmission. On my car you can not pull the governor all the way out with out lowering the transmission. I cleaned it the best I could and put it back together. I test drove the car again. No luck, car still would not shift. I took the vacuum line off for the transmission and plugged it. It shifts good now! I am guessing the lack of vacuum and the boost is messing with the shift actuator. And as for the TV cable. GM must have used that cable for the kick down for adjustability. It was dark and I do not have the headlights back in yet, so I ran it up and down the gravel road. Holly shitt this thing has some nuts now! I think I doubled the horsepower. It gets up and goes. I can't wait to take it out on the hiway.
