Thank you
Ryan
Ryan,
While things are apart, you might as well prime and paint the roof and the floor. First, I would treat and repair any floor rust. You don't want to put things back together only to have to pull it all apart again.
A wire wheel should work fine for you. You might also want to add some sound deadening to the roof.
How's the condition of the headliner board? You might also want to repair any cracks and breaks prior to recovering the headliner...unless you happen to come across a good replacement.
Us wagon guys are not that fortunate finding spare parts for our cars anymore.
If you think the carpet is salvageable, you might take it to a car wash and pressure wash it. You would be amazed how much they will clean up (especially if there are heater core stains like I had). Also, be careful on what wire wheel you use on those floors. A coarse wheel can eat through good metal if you are not careful. I would recommend a brass wheel to start with.
When you get new carpet, get the ACC brand with mass backing from Rockauto. They sell it for less than anybody else, and the quality is top notch!Thank you. Luckily the rust that is there is all superficial. A little clean up then seal it. The head liner board came out almost totally whole. Just the corners where the visors were mounted it broke off. I'm not sure if I'm going to do another headliner. Being 6'4 I kinda like the extra room even if it's miniscule.
The carpet was trashed. It was just mostly whole. It tore apart into pieces when I removed it. lol
Good call on the brass wheel.thank you
View attachment 75119 View attachment 75120 View attachment 75121 View attachment 75122 View attachment 75123 View attachment 75124 View attachment 75121 View attachment 75124 View attachment 75125 View attachment 75126 Thanks for the info guys, appears that I don't have very good locksmiths around here. They all pretty much told me I was sh*t outta luck. Oh well I'll figure something out. Where it's parked now isn't the best place for picture but I did take a few.
The front bench is pretty roachey and crunchy, also I'm 6'4 and fat so I needed the seat to move back farther. So I ripped it out and just happened to have a 95 Nissan hardbody bench seat lying around. It fits perfect and the mounts are even in line so new mounts will be super easy to make.
Now on to a bunch of cleaning!
