Yes, if you're referring to the groove on the balancerTo make sure the current timing tab was incorrect did you ensure where TDC was for that balancer? When guys toss together motors on the fly the nearest balancer usally goes on.
I dont see where you'd need the three jaw puller, NOT what you want to use to pull the balancer off with.
Good job so far getting it torn down.
What 565bbchevy said 👆🏾... And thank you for the recognition 😎Crank sprocket
Was out of my budget... I've watched a few videos of guys using the tool I bought to remove the harmonic balancer...I would buy this instead of the puller that doubles for steering wheels and this one is also an installer.
If you are going to buy tools you might as well buy ones that work well.
Yea, thought about replacing this one with a new one...When guys toss together motors on the fly the nearest balancer usally goes on.
^^Chuckles^^What's the difference between 7" balancer and 8" balancer ?
Thank you for the clarification !^^Chuckles^^
Certain set-ups work better w/a smaller diameter balancer for clearance issues. You're set-up gets the 8" balancer.
