This is subjective. We didn't swap the nylon gear out from the motor out of my '79 El Camino until 1996.Crank gear looks original. Chain and cam gear look new. I don't think there is any thing to be gained replacing any of it.
Keep in mind the original cam gear is nylon on steel, the nylon teeth wear out fairly quick so the gear has to be changed.
Yep. That one in the video was loose.What a loose chain looks like, versus how tight the chain should be..
Distributor rotor is 180° out with the dots lined up...points to firewall towards the passenger seat/door.on a chevy, when the dot on cam is at the top the engine is at #1cyl tdc on compression stroke, dot to dot is #6 at tdc on compression stroke. if it was me I would give 2 sh*ts about the tdc tool, line the dots up and put new chain in, its a tight fit so its gonna take effort to get new stuff on, tell me, is #1 spark plug wire at the correct spot on distributor??
