Look at the thread I just posted. It started out as a "little leak". LOLOne of the reasons I suggested cleaning the entire front of that motor. Lots of 'wet' coverage there. Things need to be cleaned up as much as possible to help ID trouble spots.
If extraction is a must, what tools will I need to extract it ?Should I extract it or extra tighten the remaining bolts installed ?
My thought exactly...it kinda is a big deal,if there was a bolt where that dowel's residing above it maybe it'd keep it but seeing it's the last bolt @the bottom it's a gamble.
Center punch ?Be sure to center punch the bolt and use a reverse thread drill bit.
Or this ? https://www.harborfreight.com/screw...V5kZtHBELrJGRzcjcqRf-PaPKIzXPShxoCVwEQAvD_BwEYou can try these. Be sure to center punch the bolt and use a reverse thread drill bit. Kind of stinks that the gasket is in place, because you’re probably going to damage it. Be sure to cover up the oil pan so no metal chips get in there.
YesOr this ? https://www.harborfreight.com/screw-extractor-and-left-hand-drill-bit-combo-set-10-pc-61981.html?ccdenc=eyJjb2RlIjoiNjIyOTcyMzUiLCJza3UiOiI2MTk4MSIsImlzIjoiOC45OTEifQ==&utm_source=google&utm_medium=cpc&utm_campaign=16270398380&campaignid=16270398380&utm_content=134071106632&adsetid=134071106632&product=61981&store=3227&gclid=CjwKCAiA6seQBhAfEiwAvPqu179TsSXg6wnqo5npmPN9l-V5kZtHBELrJGRzcjcqRf-PaPKIzXPShxoCVwEQAvD_BwE
