True, lets try and keep things simple here lmao.I wouldnt go for a fractional size larger. If the hole is shot I would go up the next larger size in metric. This way it might not be a huge size difference. Just a thought.
Ultra Black will work. It says the applications in the photo!Using a Permatex Gasket Maker Comparison Chart, it seems as if the ULTRA BLACK is a better fit for my job vs. THE RIGHT STUFF...
View attachment 192875View attachment 192876
Definitely going to "try it anyway" and your totally right, worse comes to worse, retry...You got a couple of options.
Add RTV to the area, then start it up, see if it leaks.
Or, extract the bolt as the other members say. If this was my only ride, I would try it anyway. If you got time, then do it all properly.
Worst come to worse, is you have to top off oil. Up to you.
I think you could be successful layering on RTV just get that area as clean as possible to promote better adhesion.Definitely going to "try it anyway" and your totally right, worse comes to worse, retry...
Great, I just cleaned the area with engine degreaser and a steel wire brush, wiped everything dry...I think you could be successful layering on RTV just get that area as clean as possible to promote better adhesion.
If you haven't applied the RTV yet you might want to follow it up with acetone, brake cleaner or carb cleaner. I have always had a film left over after using degreaser. Spend the extra ten minutes now getting that area surgically clean and it will exponentially increase your chance of success.Great, I just cleaned the area with engine degreaser and a steel wire brush, wiped everything dry...
Definitely !I see two missing pan bolts on the passenger side. Don’t want you to forget to put those back
